alternator
Ok here my question I have a 69 GMC truck my motor was bad so I put in a motor from a 1976 Malibu stationwagon and the old motor relay for the alternator was on the core support.so since new one has it built in on the alternator .how do i hook it up .the old wires were red,white,blue,black thanks
Re: alternator
Re: alternator
thank you very much
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: alternator
Here is a more informative way to do it which includes a newer alternator than yours as well as the one you have.
http://67-72chevytrucks.com/vboard/s...d.php?t=417872
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Re: alternator
I trust that you kept the short water pump and pulley setup from the 69 and did not use all the long pump stuff from the Malibu?
If you did, switch back to all the short pump stuff. You will be happier long term... the Malibu alternator bolts right into the original brackets. Then just follow the instructions as outlined above for using the internal regulator alternator.
