Rochester 2G vs 2GC
I am still going through my 66 C20. It has a 283 and the carburetor is damaged. It appears the top piece is a little warped and the rod the choke flap attaches to is broken.
I am looking for a 2G core, but not having much luck. The 2G is the manual choke version. My question is, can I use a 2GC which from what I have read is the same as the 2G but has an automatic choke and seems to be much easier to find. Thanks! |
![]() ![]() ![]() Join Date: Jan 2018
Re: Rochester 2G vs 2GC
If the base plate and stud pattern is the same, it will probably work
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
| Bookmarks |
