HEI Question
Replaced the HEI installed by PO with a new Summit HEI. Installed power wire is 12 gauge with a Female spade to connect to distributor. Has 12 volts to it.
Really tired hunting for the male dist BAT terminal with distributor cap installed when trying to connect the female to it. Saw the below on Summit and it had good reviews. However, it only has 16 gauge wire at best . Maybe 18. I don't see how I can use this given my 12 gauge wire has constant 12 voltage. Think I got ripped off for a couple of bucks! Do you agree. |
![]() Join Date: Apr 2017
Re: HEI Question
I was able to find a connector at my local NAPA that worked great. I would hesitate to go to a smaller wire like you said.
1968 GMC C2500 Long Bed Fleetside |
![]() Join Date: Jul 2015
Re: HEI Question
Using a bigger pipe to supply water that needs to be somewhat of a smaller flow anyways does not appear to be a "Big" issue.
I asked a guy whom rebuilds HEI's for a living. He informed me to limit the fuse to 7.5 amps. How much do you wish to cook the module in your HEI? According to one site I just viewed for reference a 16 gauge for Chassis Wiring will all 22 amps to flow. Its just electrical math, I am sure the developers of the product look at this. |
Re: HEI Question
I've cut this wire and connector from '76 and new GM products to get replacement connecters after the holding tab broke off.
The original factory wires are 14 gauge with extra thick, flexible insulation. I believe the extra thick, flexible insulation is used, because this is one wire that they expect you will be moving around such as when doing a tune up. Most harness wires, once connected, remain undisturbed for decades. I have connected an Ammeter in the stock HEI circuit and measured 2 Amps. 12 gauge is over kill unless you are using a low resistance. high current coil.
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 08-26-2020 at 11:08 PM. |
Re: HEI Question
To be honest I have never seen one of those. I have always seen the single power lead.
https://www.holley.com/products/igni..._content=Accel Shows the flip side of that plug and all the sudden my brain functioned and the green wire is the Tach wire. I've normally seen this type https://www.ebay.com/itm/Painless-Wi....c100677.m4598 You can find that style at Napa, or O'Reilly's normally. They may be in the Help section at O'Reillys or Autozone. You absolutely have to have that latch working though. Female slides will slip off going down the road at inopportune times. No need to ask why I Know that but trust me it isn't if it will slide off but when.
![]() Join Date: Nov 2019
Re: HEI Question
I use The Repair Connector Store for all of these type of factory connectors. Here is an HEI power & tach lead connectors.
https://www.repairconnector.com/prod...-Pigtails.html
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
![]() Join Date: Mar 2012
Re: HEI Question
i am using the same thing that i got off of a older electrical website years ago and never had a problem
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
![]() Join Date: Oct 2001
Re: HEI Question
I have that Summit one on my Mallory HEI. Red is distributor power. Green is tach lead. Points wire was 12ga but also is a resistor wire rated at 9.3 volts so the points don't burn up.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
Re: HEI Question
I installed the the same thing on my 71 C10 350 sb, no problems in the 2 years, even use it as a kill switch for anti theft
Will it work fine ? .
Yes . Is it good practice to change the gauge of any wire anywhere in a power circuit ? . No .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
