Gas tank neck
Does anybody sell just the gas tank neck. I am removing tank from behind seat but am not doing body work at this time. I am afraid to cut neck off of existing tank.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
Re: Gas tank neck
I seen one post the fellow welded a bolt to the gas cap used a bar and a wing nut to secure the gas cap to the truck
It serves double duty close the hole and wont allow a gas station attendant to fill your cab with gas safety feature |
Old member
Fill the tank with water up to the bottom of neck and cut it off. It want blow up with water in it! You can even turn a fan on and keep the neck in the wind stream.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Feb 2019
Re: Gas tank neck
Can you use a Pipe cutter? it doesn't generate any heat to worry about..
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
Re: Gas tank neck
Thanks for the ideas.
Re: Gas tank neck
My tank was outside for about a year open to the elements. I didn't even think of sparks or heat when I took my sawzall to it last month.
Re: Gas tank neck
Depending upon the year, it may not be necessary to remove the filler neck. I removed the tank from behind the seat of my 70 C-30 as one piece.
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Re: Gas tank neck
You can see this in my build thread post #13, https://67-72chevytrucks.com/vboard/...d.php?t=782232
I decided to keep the original fuel fill hole. I welded a stud onto the back of the fuel cap and used some washers to double-nut it in place. I didn't want to hack off the original filler from the tank, so I don't have any of the filler neck showing.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#9 | |
Re: Gas tank neck
This is great. How did you keep from burning the finish off the cap while welding?
Re: Gas tank neck
The stud doesn't touch the outer part of the cap. There's an inner part of the cap that I could weld to.
Re: Gas tank neck
Thank you. That is what I am going to do for now.
Re: Gas tank neck
Darrens thread was the one i seen i will do that to my trucks atleast until i hit paint stage
Safe hit the gas station tell the person fill it up you go inside they wont be filling the cab with gas That looks like a service mast square washer you used |
#13 |
Re: Gas tank neck
Good eye. You must be familiar with those.
