Old 08-27-2020, 08:26 PM   #1
layinrocker65
layinrocker65's Avatar
What lowering spring should I buy. Cut springs aren't low enough
I want to lower the front of my truck more. Currently have Moog BB springs that are cut 1.5 coils. When I put the springs in new to replace the stock woren out springs, I cut them one coil and the ride was good. Now that I have cut more to lower the front more, I have reached the point of diminishing returns with the ride quality. I have shorter bump stops and I am not bottoming out.
Current suspension setup is CPP lowering spindles(2.5"), cut coils and a rear flip. Wanting to lower the truck another 1" in the rear and lower the front so it has the slightest rake. I think a 3" lowering coil will get me there or really close.
Anyone have 3" springs that can comment on ride quality and which ones they went with? I searched but could not come up with any good answers.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 09-03-2020, 07:55 PM   #2
wixthedog
wixthedog's Avatar
Re: What lowering spring should I buy. Cut springs aren't low enough
I dont have an answer for you but I am interested to know how much (or little) ground clearance you have on your LCA's. I run 2.5" drop spindles and 2" springs and it was ridiculous to drive so I swapped the springs for 1" drop versions and it made quite a difference.
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
Old 09-08-2020, 07:41 PM   #3
Tom
driving is in my blood
Tom's Avatar
I have 3" spindles and 2" springs on my 78. Always get the most drop from the spindle or LCA's as you can to preserve ride quality.
I have 3" springs on my 98 since they only make 2" spindles. They are western chassis springs are ride excellent. I'd go with them again in a heartbeat.
