08-28-2020, 02:03 PM | #1 |
Above visor rust
Been looking for a good truck to restore over time. Found a truck I like, but any rust repair/welding work I don't usually attempt myself, so thats something I would have to outsource to someone else. The truck im looking at has at least 8 places about the size of a nail head above the visors. I want to keep any truck I decide to buy original, so I don't want to swap cabs. The floors seem to be in good shape, the drip rail is pretty good, may be 2 or 3 places that need some work.
I guess my question is, is roof rot worth fixing or do most just get a different cab? I know its really about what you want to sink into the cost of a truck as anything is fixable if you have the money, but just getting feelers on what issues people usually will fix on trucks and which ones they will steer clear of. |
08-28-2020, 02:14 PM | #2 |
Re: Above visor rust
Depends on your area and how far are you willing to go to get a more rust free truck
I have driven across Canada and the USA to get a more rare short box 4x4 trucks in the past They do make a patch panel for the area above the visors so many people have had this issue Roof skin in fair shape ? I would suggest new seam sealer after repairs to the header panel Best bet i would say take it to your body shop of choice for an estimate |
08-28-2020, 04:59 PM | #3 |
All about them K’s
If your dead set on that truck and keeping the original cab, replacing the entire roof off with another rust free unit is likely your best option. If you’ve got pin holes or even bigger rust holes your guaranteed to find a lot more when you cut it open.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
08-28-2020, 05:30 PM | #4 |
Who Changed This?
It's like Swiss cheese- once you cut into it, you find more holes!
08-28-2020, 06:06 PM | #5 |
I live right in the middle of the state of Missouri and most all the cabs I have seen recently have from moderate - few / small holes above visor to gaping hole you can stick your hand into. I keep having folks call me for a 'rust free cab' - I really hope they find one, but don't give them much hope of doing it.
The old remedy was to graft a donor roof on to the old cab, but I haven't see any donor roof sections lately that weren't eat up with rust too. I figure if the demand continues and the availability of good parts totally dries up, then a company - think Dynacorn or similar - will take all the reproduction body parts and offer a complete body just like what happened with Model A's, AD series trucks, Mustang fastbacks, etc. I have seen some ambitious folks who drill out the spot welds around the perimeter of the cab roof and cut through the spot welds up across the upper back of the cab to take the top skin off so that they can access the inner panel to repair it and rust proof the rest once it is revealed.
PayPal 1windyridgeboy@gmail.com |
08-28-2020, 08:34 PM | #6 |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-28-2020, 10:34 PM | #7 | |
08-28-2020, 10:51 PM | #8 | |
If you're in the DFW area I recommend Jose's Auto Body & Refinishing, 3735 E University Dr, McKinney TX 75069, 469-288-0327 Jose put the old windshield in the bed and I took it home, and I gave it to another forum member, as it was still OK although not perfect. Jose showed me the drip rail and explained that I should put seam sealer there to keep it from getting more water in the patch panel that he just replaced, to keep it from rusting again, and also showed me the inside fender area that goes to the kick panel vent was full of leaves and told me I should clean that out. He was leaving the stuff I could handle to me, at my request. |
08-29-2020, 03:30 AM | #9 |
I have two areas I do not mess with. Cowl rust and roof rust. There are just too many other trucks out there without rust in those areas. I do not mind cab corner or rocker rust as I truly think they all have some sort of issue there. Even if it is just a pin hole; that means the entire panel is infected and needs replaced. $500 for that repair is beyond reasonable. Most shops are here wont even touch something this old as they stick to insurance jobs.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
08-29-2020, 12:01 PM | #10 | |
Sometimes we all have to play the hand we are dealt? Maybe if your pockets are deep enough you travel several hundred miles to get a solid truck or pay to ship it to your door, but most folks will try to get the best / least rusted up cab they can afford and then count on doing the work themselves so that it doesn't run them broke paying someone else's labor rate. The end result isn't always up to professional standards maybe, but it is the best the person can do with what they can afford and still be a part of this truck hobby - which I hope is why we all chase after these trucks and parts to repair them. Just my two cents worth - probably all it is worth. Jay
08-29-2020, 07:04 PM | #11 |
Mine had a few spots above the windshield gasket so i just cut them out nice little rectangle cut then went back with Ospho in a garden sprayer and douched the whole inner section of the roof skin and down the sides of the windshield frame and back of the cab section till it was dripping out the bottom. I figured this would help slow anything down until i can get the cab in the body shop. BEst to treat it now so it does not grow
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
08-29-2020, 07:16 PM | #12 | |
09-01-2020, 12:58 PM | #13 |
Although there is the occasional "rust free" cab show up occasionally, they are usually priced to the point that they aren't worth it(for me). I've never seen one that was truly rust free. A truck with a little rust above the visor is totally fixable. Just cut it out and weld new steel in. After the repair, you can spray rust paint through the visor holes to help prevent it from coming back. I always spray oil in the visor holes before I install the visor. Make sure that you properly reseal your gutter.
