Old 08-28-2020, 03:16 PM   #1
Maimux1
72 Chevy 4x4 auto 400 turbo
Can anyone help? I have a 72 Chevy 4x4 and want to install a 400 turbo. Some have said I have to move the cross member? Just would like to know what all is involved to install a 400 turbo in a 72 4x4. Any help would be appreciated. Thank you.
Maimux1 is offline   Reply With Quote
Old 08-28-2020, 04:40 PM   #2
Bigdav160
Bigdav160's Avatar
Re: 72 Chevy 4x4 auto 400 turbo
I believe there are differences in the transfer case so the TH400 doesn't bolt directly to a NP205 that came with a TH350 in front of it.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-28-2020, 04:53 PM   #3
Maimux1
Are you talking about the adaptor that goes between the transfer case and transmission? I have the auto 400 adaptor that come with the 400.
Old 08-28-2020, 05:35 PM   #4
Mike C
Mike C's Avatar
The spline count on the output shaft is different on the TH400. You will need a different input gear on the NP205. You will have to move the cross member back. You will need to shorten the rear driveshaft and lengthen the front shaft.
This gets expensive and you need to really have a need/want to go through with this IMO>
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-28-2020, 09:26 PM   #5
57taskforce
All about them K’s
57taskforce's Avatar
If you don’t have a turbo 400 or late style sm465 np205 you’ll have to machine the transfer case to accept the turbo 400 input bearing.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 08-28-2020, 10:14 PM   #6
Maimux1
I had no idea there was that much involved to make the 400 work. I would be better off money wise to use a th350 it sounds like.
Old 08-28-2020, 11:04 PM   #7
Jcfcamaro
Jcfcamaro's Avatar
I'd build a good turbo 350 and skip the headache. Doesn't a turbo 400 have a solenoid or switch that you have to run off the carburetor also.
Jcfcamaro is offline   Reply With Quote
Old 08-28-2020, 11:29 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Yes , a kickdown switch. The '72 would be located on the accelerator pedal bracket, inside the cab.
LockDoc
Leon
