08-28-2020, 04:41 PM | #1 |
window motors
1978 c10.. there is a left and right window motor. I am working on my power window door assembly (bought truck in pieces so I am learning as I go) . do both motor plugs face the back of the truck??? The motors I have , the pass plug faces the back of the truck and the drivers faces the front. I cant see how I can hook up the plug to the drivers side motor at it is very close to the inside of the front door side. Going to pull the reg and motor is there a way of identifying left from right I may have a wrong side motor installed. Thanks
08-29-2020, 12:58 PM | #2 |
Re: window motors
This may help you can see the wiring.
https://www.youtube.com/watch?v=dki5EJkXPic
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
