![]() Join Date: Apr 2009
1965 Pacific Bellsouth
Dose anyone Have One In this Group Or seen one there The most Perfect Service Beds Out there
1963 Impala 2021 Harley Road Glide 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2006 Silverado 1500 Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
#2 | |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Re: 1965 Pacific Bellsouth
That would be way cool to drive around in!
Have Family up in Simi spent a lot of My Youth Summers there
60-66 Nut
![]() ![]() Join Date: Mar 2007
I have a '63 short wheelbase C10 that was apparently bought new by General Telephone and Electric with a utility bed on it. Under the current paint and in the back is the GTE yellow that is similar to Caterpillar yellow. There are no bed mounts on the frame. The utility bed is not exactly like the one in the pic, but it is similar. The cab unfortulately has the yellow revolving light and a spotlight on the roof.
Haven't seen this member in a while but always liked the utility bed on his truck..
AtRockdriller http://67-72chevytrucks.com/vboard/s...d.php?t=453161
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
![]() ![]() ![]() Join Date: Jan 2018
We are thinking that Flashed's service bed 65 is an old Southern Bell truck. It has a paint code on the data tag I've never seen before, and has some green paint similar to the first picture in this thread that's under some maroon primer. His truck has the same bed as Captainfab's 63
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
But Found Her 25yrs Later!
I just bumped this thread up again:
http://67-72chevytrucks.com/vboard/s...d.php?t=471900
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
| Bookmarks |
