Old 08-29-2020, 01:58 PM   #1
Sensor for Tune Ups?
I was wondering if any of you folks that run carbs still if there is some sorta )@ type sensor that can be used to adjust the carb setting with? The 4bbl (500 CFM) on my 81 and it is running really rich. I have the kit to tear into the Edelbrock, but it would be nice to know with some sorta gauge to see what is coming out the pipe without having to run it a while, check the plugs and all. I have not down a carb reject/rerod (whatever you call it on an Edelbrock) in 30 years.
Thanks for the help.
Old 08-29-2020, 04:26 PM   #2
geezer#99
geezer#99's Avatar
Re: Sensor for Tune Ups?
Running real rich on an eddy is usually too much fuel pressure.
Have you got a regulator set to 5 psi.
geezer#99 is online now   Reply With Quote
Old 08-29-2020, 04:34 PM   #3
Its the factory fuel pump on my 250, which isn't real hig output..
Old 08-29-2020, 06:39 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
Have you performed the basics? Timing and set idle/mixture with vacuum gauge?
Also, checked to ensure choke is opening all the way after warm up?
Old 08-29-2020, 06:47 PM   #5
Dead Parrot
The normal tuning gauge is an Air Fuel gauge but they require an O2 sensor be mounted in the exhaust system very close to the transition from exhaust manifold to pipe.
Make sure the choke is adjusted properly.
As mentioned check for fuel pressure.
If you take the carb apart, check for proper float height.
The nice thing about the eddy carb is you can change the rods and power piston springs via the little access caps on top.
If the carb has been in service for a while, maybe all you need to do is pull the caps and give the pistons and cylinders a good soaking in carb cleaner. They can get gummed up and sticky after a few years. Would also let you check what rods and springs are installed.
Depending on what carb you have, possible it was sold as a "Performance" carb and those are usually rich for a daily driver.
The manuals came with a calibration chart for making adjustments. You might check which rods you have and order a set that is a bit leaner on the chart. Same for the springs.
Dead Parrot is offline   Reply With Quote
Old 08-30-2020, 07:37 AM   #6
Everything is new. Timing and fuel pressure is good. Choke appears to open all the way. I just can't go lean enough on the carb with the out of the box jetting. I was just curious if there was anything out there like you see the EFI guys use to monitor fuel mixture. I'll probably be getting into opening up carb and rejetting it. This is all on the new tweaked some 250 I put into the truck. It is old style heard, cam, 4bbl Offenhauser intake, the new Edelbrock 500 carb and headers.
Old 08-30-2020, 12:44 PM   #7
Pontiac1976
Pontiac1976's Avatar
This may help: one of the better ones If you still want to stay with Carb
https://www.youtube.com/watch?v=YiUDltHKnLE
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-01-2020, 12:29 PM   #8
truckin 79
I installed a AEM wideband O2 sensor in my truck and is the best thing I ever did as far as tuning. It helped me pass emissions here in CO. The gauge does become a litte addictive watching it as you driving to see what air/fuel ratio is.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
