Old 08-29-2020, 11:48 PM   #1
Factory Guy
Factory Guy's Avatar
Wiring dash cluster 1973
I did a search on this site to try and find a simple looking plug wiring diagram like this for my 1973 GMC C2500.
Ideas where I can find these detailed diagrams?
Just the correct stock locations of the pins.
Factory Guy is offline   Reply With Quote
Old 08-30-2020, 12:26 PM   #2
kglowacky
Re: Wiring dash cluster 1973
This is my wiring diagram I made on my 1978 C-19. I was like you could not find anything that matched my wiring colors. Please use this keeping in mind my drawing may not fit yours exactly . good luck I installed a Painless universal kit so I show the painless wiring colors also. Please excuse my poor hand handwriting but as I am working and trying to write my handwriting is horrible
kglowacky is offline   Reply With Quote
Old 08-30-2020, 12:49 PM   #3
Pontiac1976
Pontiac1976's Avatar
Try this link:
http://forum.73-87chevytrucks.com/sm...?topic=31290.0
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-01-2020, 11:21 AM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
Try member Hatzie's thread where he has pdf files you can download of the complete wiring diagrams:
http://67-72chevytrucks.com/vboard/s...d.php?t=545416
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
