Old 08-30-2020, 10:20 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
Window channel
I changed the vertical window channel a while back to stop rattling, but the window frame is digging into it and shredded it. This also hangs the window up, puts stress on the regulator and won't let the window go all the way up.
What am I missing? I left the channel in the truck and used a small metal scraper through the metal channel. Then put some of the black goo on it and pushed it in. What am I doing wrong? Did I just buy something that we're too thick? Any tips would be appreciated
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 08-30-2020, 10:27 AM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: Window channel
This is what I ran into when I put my new precision division bar felts in. It sounds like maybe you’ve got the same problem.
http://67-72chevytrucks.com/vboard/s...d.php?t=805892
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 08-30-2020, 11:25 AM   #3
phlegm
phlegm's Avatar
Re: Window channel
Thanks! That's it, ugh I was hoping I could avoid taking the regulator apart....
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 08-30-2020, 11:30 AM   #4
57taskforce
All about them K’s
Re: Window channel
Yeah the doors will have to come back apart. I trimmed the corners on mine with a die grinder. It will take longer to take it apart and put it back together than it will to fix the problem.
Tyler
Old 09-19-2020, 09:24 PM   #5
phlegm
phlegm's Avatar
Re: Window channel
My rubber tape at the bottom of the window is cracking, did you replace it with anything? I am cant find anything the right thickness, I am thinking of getting a tire inner tube and cutting it maybe using a little silicone for adhesive becuase the window has been slipping out.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 09-19-2020, 10:00 PM   #6
57taskforce
All about them K’s
Re: Window channel
No, fortunately for me both my windows were still set tight. I would think urethane would hold up like truckdude said.
Tyler
Old 09-19-2020, 09:39 PM   #7
truckdude239
truckdude239's Avatar
Re: Window channel
U can buy window urethane at advance auto it will be stronger then rtv
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-19-2020, 10:23 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Window channel
A local auto glass shop may have the setting tape you need and some non-pickup aftermarket suppliers sell it as well.
Old 09-19-2020, 10:50 PM   #9
phlegm
phlegm's Avatar
Re: Window channel
Didn't think of that! I know just the guy
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 09-21-2020, 09:44 AM   #10
phlegm
phlegm's Avatar
Re: Window channel
My glass guy said he doesnt replace the worn rubber anymore because they are hard to find and all different sizes (for different vehicles) now he runs window urethane in the channel effectively gluing the window directly in. Thoughts?
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 09-21-2020, 10:12 AM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Window channel
Sounds like he’s taking the easy way out to me. Not that it won’t get that job done but what happens if/when the glass needs replacing? Digging out the sealant wouldn’t be fun especially from a vent window.
Old 09-21-2020, 10:18 AM   #12
phlegm
phlegm's Avatar
Re: Window channel
This is the main window, not the vent one... not that / that matters. I went out into the shop after talking to him, I think I am going to leave the old hardened one in there and use the black weatherstrip stuff to give it a little extra grip and call it a day.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 09-21-2020, 10:41 AM   #13
Woodnears
Re: Window channel
I just did this last week! Here's a hint, go to your local glass shop if they are decent humans they will give you a partial left over tube of urethane. Tear it apart, trim a little off the front of the channel and then glue that sucker back in place. I let it sit overnight then reinstalled everything. Works great now!
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417
Woodnears is offline   Reply With Quote
Old 09-21-2020, 11:01 AM   #14
phlegm
phlegm's Avatar
Re: Window channel
I agree, I think I am going to do this with the weather strip stuff. The window was pretty solid until the felt dropped and pushed it out (long story) I dont think it needs much. we have a few sunny days in a row, I wont install the sweeps until I know this works, then if I find I need more it will be an easy job to pull it again.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
