1960 cab replacement
Hey guys, I got rear ended and the rear of my cab was damaged. I was unable to find body panels to replace the back panel so I am looking for a cab replacement with a small window. Do you guys know if any other cab years will fit on a 1960?
also looking to replace the rear frame up to to the rear shock mounts (about 3' of frame). any ideas on that, besides getting a donor frame? thanks guys 1960 chevy apache, short bed step side. so far I have heard the torsion bar frame 60, 61 and maybe 62 would be the same, will my body and cab bolt on a 63-66 frame? Last edited by Jesster3757; 09-01-2020 at 12:40 PM. |
![]() Join Date: May 2015
Re: 1960 cab replacement
Cab looks fixable...unless theres more than the pic shows..I would think the frame would be the biggest concern..it looks nasty....
other driver with no Insurance?
![]() ![]() ![]() Join Date: Jan 2018
With the amount of damage on your frame, a frame swap is probably in your future. On the cab, a good body man can fix all that, but if you choose to get another cab and frame, it might be easier to just start with another truck and use the wrecked one as a parts truck
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
other driver has insurance luckily, truck appraised for 27k so the insurance is willing to spend 18k to fix.
#5 | |
Sounds like you have a good insurance company! Also, if you decide to look for a donor cab to use for the back wall, all 60-66 back walls are the same
The back walls are the same but I don't think you will be able to use the door opening because I think the latches are different
Chevy addict
A good frame shop can straighten your frame and a good body shop can fix that cab
But Found Her 25yrs Later!
It may or may not matter to you, but if you have a Chevy, there is a VIN on your frame - which should match the VIN on your cab.
If you have a gmc, there isn't a VIN on the frame. My 65 Chevy is on a 62 gmc frame. The 63-66 bed mounting doesn't line up with the 60-62, but you can make it work. For the cab, only the front cab mounts don't line up.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Reading back over your post, I'd keep as much of your truck as possible. Although, did the insurance company consider it totaled?
| Bookmarks |
