Old 09-01-2020, 08:59 AM   #1
Big70
Tail light gaskets/Reverse light gaskets/Screws
OK I'm putting in new tail lights and cleaned up my housings. My question is, are there two different gaskets between housing and plastic lenses? it seamed like there was a thick rubber in the housing and my local c10 shop said no there is only the foam style ones that he can get me.... The other question I had is when I removed the factory housing there were rubber like bushings around mounting screws and my pops said there were there to keep the housings from rattling around and knocking out bulbs and what have u? That is another part my c10 shop has no clue about... Im I missing some thing here? The gaskets I got with my new lenses seam way to thin compared to the factory ones I pulled out. Any help is always good help thank you!
70 custom10 swb fleet side 454 th400
Big70 is offline   Reply With Quote
Old 09-01-2020, 12:52 PM   #2
Smitty
Smitty's Avatar
Re: Tail light gaskets/Reverse light gaskets/Screws
I pitched the flimsy foam ones and bought a pair of 9342 Soft Seal. I think that they are available through Jegs. But you can Google the number and shop for the best deal.These are solid foam and about 3/16 " thick. Will prevent any issues with rattle or leakage. https://www.jegs.com/i/SoffSeal/854/9342/10002/-1
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 09-01-2020, 04:48 PM   #3
Smitty
Smitty's Avatar
9341 is the soft seal pt# for the backup light gasket. Also available at Jeg’s.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Old 09-02-2020, 07:50 AM   #4
sick472
sick472's Avatar
I used the thin light duty foam ones AND some rope caulk. I put the rope caulk in first, then the foam gasket. This makes for a tighter seal and the rope caulk will smush to make it equally tight all around while the foam gasket makes it easy to get the lens back out without it sticking. Better gaskets could be a better way to go, but I always have rope caulk laying around and have found it to be great stuff in places like this.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 09-02-2020, 09:12 AM   #5
Big70
How long do you wait to put the lenses in after you put the rope caulk in? Do you let it set up at all?
Old 09-02-2020, 09:14 AM   #6
Big70
Does any know about any rubber anti rattle o rings around the screws that hold the tail light housings to the bed sides?
Old 09-02-2020, 09:16 AM   #7
Big70
Ow I see now it does not set up you just put it in like backing rod.... thanks for the tip!!
Old 09-02-2020, 09:18 AM   #8
Smitty
Smitty's Avatar
If you have a sample or idea of the size check out a hardware store that has an assortment of o rings in a box. Ace hardware or Fleet Supply might be possible sources.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
