Removing Crossmember Studs
In the Process of a teardown of my 63 C10. The crossmember stud threads that hold the upper control arms are damaged and need to be replaced. LMC has replacement studs listed as Bracket Studs. I am going to assume they are pressed in. What is the best way to remove them and then replace them.
![]() Join Date: May 2015
Re: Removing Crossmember Studs
Maybe press them out..or a air Impact hammer may drive them out...
when removing rivets in a truck frame center punch in the middle drill with 5/16 or 3/8 almost all the way through the rivet then use a larger bit and mill away the head and drive the rivet out using a 1/4 punch using the smaller punch then the hole you drilled lets the rivet collapse around the punch.
Moderator
![]() ![]() Join Date: Aug 2011
I think are splined, I saw those for sale someplace online but I can't remember where right now.
See if these are the right dimensions - https://www.speedwaymotors.com/Repla...RoC5ewQAvD_BwE No I think ours are 1/2" stud x 3.125" long? Item #8 "should" work for our trucks - https://www.lmctruck.com/1967-72-che...-2-wheel-drive
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 09-01-2020 at 03:35 PM. |
Thanks for the replies. I can cut off the bolt from the inside and try to hammer out the remaining with the head on the opposite side, but I don't want to bend the bracket. I can't grind the head off due to it being in a concave part of the bracket. After knocking out some frame rivets and upper ball joint rivets with a punch and hammer yesterday I'm worried these will be a little more than my scrawny arms can handle. (No air compressor and accompanying tools yet) I know my grip thumb and finger would want an alternative to that, like an air compressor and accompanying tools.
Rocknrod they do look like they should be splined though. They are about 3.125 inches long and 1/2 inch thick. LMC does have them for a 63. If they are splined maybe they would come out similar to a wheel stud? I'll try a little hammering to see if any progress can be made. Just don't want to bend anything. |
Does anyone know if this smaller spacer comes off or is it part of the bracket? The replacement spacer on the LMC diagram looks square and only shows one. All be it its a drawing, probably not an accurate depiction. Mine are round and are two part. One is convex the other is concave.
![]() Join Date: Apr 2011
Maybe drill them out from back side?
![]() Join Date: Jun 2006
You can press them out using a ball joint press or a beefy C clamp and a socket over the wide base.
1966 GMC 1 Ton 305 V6 SM420 4 speed - retired Fire Dept Support Truck from Little Falls, NJ My GMC Photos |
![]() Join Date: Feb 2010
I just replaced the crossmember on my 70. Looks very similar to yours. The studs are just like lug nut studs serrated on the ends. I just heated around the head and pounded it out. There is two size studs as you can see in my one pic. The concave washer you showed comes out also. My upper a frames came off the smaller studs shown but slid on the bigger studs just fine. Sorry about the wrong year forum. I'm a closet 60-66 wanabee.
| Bookmarks |
