09-01-2020, 11:45 AM | #1 |
tail and brake lights
I'm installed a American Autowire Power Plus 20 harness in a 69 C10. When I went to connect the the rear light harness I made. When I connected the wires to the drivers side Tail lights. The tail light powered on and stayed on. I connected the the passenger side and the tail light was off. The only way the passenger light turns on is when I turn on the light switch. Both turn signals work properly. I still haven't added all my ground connections. Could the grounds be the problem? Also when I apply the brakes the tail lights don't do anything and the reverse lights as well.
Thanks, Ramiro |
09-01-2020, 02:48 PM | #2 |
Proprietor of Dale's Corner
Re: tail and brake lights
Until all the grounds are hooked up you won't know what's working or not.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
09-01-2020, 05:26 PM | #3 |
09-01-2020, 06:01 PM | #4 |
Awesome, I hope everything works!
09-01-2020, 10:48 PM | #5 |
Ol Blue K20 thanks. I have installed 3 grounds so far. I started from the rear. I installed 2 ground cables from the frame towards the rear of the bed. One on each side. The next ground cable I installed was from the cab to the frame just behind the passenger door. Still having the same issues. Tomorrow I will add a few more grounds. 1 from the motor to the frame, the inner fender well to the frame and from the frame to the core support. Hope fully this takes care of the problem I’m having. Here are the ground cables I made. I used 4 gauge cable with copper lugs.
Thanks, Ramiro |
09-02-2020, 01:30 AM | #6 |
The tail lights shouldn't work at all unless the switch is turned to an on position., Either park or with headlights on.
09-02-2020, 09:44 AM | #7 | |
Thanks, Ramiro |
09-02-2020, 01:25 PM | #8 | |
Old member
Now as far as the wiring goes the head light switches sold today are for 71-72 trucks mostly. The 67-70 if I remember right are different from the other's on how the wires hook up. You need to trace out the Auto wiring harness and make sure you didn't cross a wire up.
09-02-2020, 02:35 PM | #9 | |
Thanks, Ramiro |
09-02-2020, 03:05 PM | #10 | |
Old member
I can understand that. Hopefully it's a simple fix. Here is the schematic for this type truck. It's a general one that covers all the 67-72 trucks. You can down load it and use paint to open it and make it bigger.
09-02-2020, 03:35 PM | #11 |
Msgt USAF Ret
you should have one wire going to the tail lights from the front connector, usually dark brown. At the rear connector this wire feeds two wires to the left and right tail light.
There will be a dark green wire to the right brake/turn light and a yellow wire to the left brake/turn light. Trace the right tail light wire back to the rear connector and see if it goes to the brown wire and then see which wire goes to the left tail light. Like Andy said the left tail light wire is coming from a full time hot source from the key off circuit. Did someone wire in a trailer connector at some point? Here is the harness for the 67 to 72 trucks. The license plate light also gets power from the brown wire.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 09-02-2020 at 03:42 PM. |
09-02-2020, 04:00 PM | #12 | |
Ramiro |
09-03-2020, 09:34 AM | #13 | |
Thanks, Ramiro |
09-03-2020, 09:49 AM | #14 |
Old member
The black wire coming from the steering column should be the horn ground wire.
09-03-2020, 09:54 AM | #15 |
09-08-2020, 10:10 AM | #16 |
Well I had 2 wires connected wrong on the rear light harness I made. Made the corrections. Now both rear lights are on. I press the brake switch and they go off. I looked at the connections from the American Autowire fuse box and every thing looks correct. I checked 3 wires on the connector that comes from the fuse box to the steering column. The white brake switch wire has constant power also. The yellow and Green tail light wires have constant power when the key is on? I cleaned the area where the tail light buckets go into the bed. To make sure I'm getting a good ground. Not sure what I need to do next.
Thanks, Ramiro |
09-08-2020, 11:33 AM | #17 | |
Msgt USAF Ret
The purple wire only has power when the key is on. It comes from the fuse panel turn signal flasher. The brown wire has constant power, when the emergency flasher switch is closed it sends power to all four turn lights, the brakes and turns are the same lights in the rear and they share the yellow and green wires. I have a diagram of the three wires and their positions in the column harness plug that I will post for you. I remember that the white wire goes on one end and the black wire goes on the other end. Here is a picture that should help. His left hand is the wiring plug from the fuse panel.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 09-08-2020 at 11:44 AM. |
09-08-2020, 12:15 PM | #18 | |
The white wire should only have power when the brake switch is pressed? I was checking the white wire on the steering column connector. I will take a picture of the steering column connector. Ramiro Last edited by Ramiro0727; 09-08-2020 at 12:22 PM. Reason: adding information |
09-08-2020, 02:33 PM | #19 |
Here is the picture of connectors on the steering column.
09-09-2020, 10:42 PM | #20 |
Well I have got the issue with the brake lights corrected. It was the brake switch. Now everything works. But when I turn on the headlight switch the turn signals don’t work in the rear. The front ones work correctly.
Thanks, Ramiro |
