Old 09-01-2020, 12:40 PM   #1
68Gold/white
Your preferred cab/core support mounts, rubber, plastic???
My 67 and 68 both need cab/core support mounts...
Nothing lasts forever. I've seen plastic suspension parts get brittle and crumble, after NOT TOO long on a vehicle. AND we know rubber doesn't last long either.
A preferred brand? Rubber O.E. type? aftermarket plastic?
Thanks!!! in advance!!!
Jeff
68Gold/white is offline   Reply With Quote
Old 09-01-2020, 02:15 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Your preferred cab/core support mounts, rubber, plastic???
Jeff
I only use the rubber kits. The supports were designed to absorb vibration and road shock and the plastic or Poly ones will not do that.
LockDoc
Leon
Old 09-01-2020, 04:27 PM   #3
Rubber lasts plenty long. There are original mounts out there that are still doing their job. Are all of your original mounts bad?
