Old 09-01-2020, 03:09 PM   #1
BK'66Step
BK'66Step's Avatar
Where to find cab-to-frame mounting hardware??
Hi guys!!
The old rubber cab mount bushings on my '78 K10 were toast so I decided to replace them with ES poly bushings. The job, overall, has been significantly easier than i expected! However, I have found that the "sleeves" that the bushings slide on to are pretty rotten and need to be replaced. I found a kit that supplies the sleeve, bolt, washer, and new rubber but it looks like its backordered at least 2 months. Does anyone know where I could buy (or does anyone on here make) just the sleeve? Seems like someone with decent welding skills (not me) could make one... my rear cab mounts are fine, its just the front cab and the radiator support mounts which i believe are the same size. Any leads on these would be great!!
BK'66Step is offline   Reply With Quote
Old 09-01-2020, 05:30 PM   #2
kwmech
Re: Where to find cab-to-frame mounting hardware??
It is not necessary that they be welded. Measure out and source the sleeve, then find a matching washer.
Old 09-01-2020, 06:58 PM   #3
BK'66Step
BK'66Step's Avatar
Oh I hadn't considered that! I think I can get my hands on some 7/8" pipe... thanks!
Old 09-10-2020, 10:32 AM   #4
TrailerTrash
TrailerTrash's Avatar
I used Energy Suspension. The kit came with everything I needed. My stock parts were even worse than yours hardly anything left of them
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
