Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 09-01-2020, 11:28 PM   #1
Transam461
1967 C40 Rear Axle Rating?
Good evening everyone, I am working on a 1967 Chevrolet C40, and I need to replace a bad power brake booster, which is mounted under the cab. They want to know what rating the Rear Axle is in it, so I need your help. It is a 1967 C40, L6 292 engine, single rear axle with duals. The tag inside the drivers door jam says the truck is rated 16,000 lb GVWR. The tag that is inside the glove box says it is a Model CS41403, and I also see that it says "RR Spring 15,000 lb" on the tag, but I wasn't sure if this was refering to the Rear Axle rating or not, as I wasnt sure what the "RR" stands for. Can someone help me? What is the rating of the Rear Axle in this truck? Thank You
Brian
Transam461 is offline   Reply With Quote
Old 09-03-2020, 07:34 AM   #2
Re: 1967 C40 Rear Axle Rating?
I rambled some on this question in your original thread. Does your truck have the SPID on the glovebox door?
http://67-72chevytrucks.com/vboard/s...d.php?t=811411
Old 09-08-2020, 08:16 AM   #3
CarolinaHD
Moderator
CarolinaHD's Avatar
Post a pic of the rear axle, it's either 11k, 13.5k, or 15k pound rear. It's more than likely you have the upgraded 5k front axle with the 11k rear=16k gvwr. I'm not postive what RR stands for but something to do with the rear. 7.5k leaf spring option is the 15k rr springs on your spid
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 09-08-2020, 01:20 PM   #4
MJN
MJN's Avatar
RR is simply the abbreviation for Rear
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 09-08-2020, 02:31 PM   #5
CarolinaHD
Moderator
CarolinaHD's Avatar
Thanks! Ive always wondered, I assume they use FF for front?
Alex
Old 09-08-2020, 03:08 PM   #6
MJN
MJN's Avatar
FRT is front
'17 GMC Yukon XL
VCCA member #58596
Old 09-09-2020, 01:02 PM   #7
rkn463
rkn463's Avatar
I think the rear diff will have numbers stamped in to it, can you find those?
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 09-30-2020, 08:39 PM   #8
What you'll have is an HO110. All I know is the minimum factory rating is at 11k# and that is an option on the 1t (light truck configuration. Rating up from there depends on spring options
