09-02-2020, 12:29 PM | #1 |
Dust Shield Question
OK folks, I got a conundrum. I am putting the front end back together and am almost to the point of needing dust shields. I have this set of '73 spindles with these factory dust shields I could pull, clean up and use or I could pop $50 for a set of new repops.
What are the thoughts here? These have two "slots" for lack of a better term but most I see repop are solid.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra Last edited by 67C10Step; 09-02-2020 at 01:26 PM. |
09-02-2020, 12:39 PM | #2 |
Re: Dust Shield Question
Spend the money on shiny go fast bits.
09-02-2020, 12:49 PM | #3 |
Those look good, I would use them.
09-02-2020, 01:16 PM | #4 |
Old member
If they will work use them. Save the $50.00 for something you don't have. If the 73 will fit clean them up and install, they will never be seen so don't go to a bunch of trouble on them. Well unless your going for show instead of go!
09-02-2020, 01:31 PM | #5 |
Right now I am working on the woah! before the go! Thirty plus years ago it would have been the other way around.
This truck is a budget build. Not a daily driver but definitely will be driver quality all the way. I think I'll clean them up and see how they fit. Worst case is I'll stick them back on the 73 spindles and hold onto it all. Here is my current state of things:
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
09-02-2020, 03:45 PM | #6 |
