Old 09-02-2020, 03:59 PM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Lokar ACA-1804 2" Column Cable Shift Linkage Kit
Brand new and unused. I bought this to use on my build, but ended up going with Lokar's rod style linkage kit (ACA-1800) instead.
$110 Shipped -- SOLD
Payment by PayPal; buyer pays any fees; shipped to lower-48
Lokar 2 inch Column Shift Linkage for GM Aftermarket is the ultimate answer to interference issues when you are unable to use factory or Lokar's hard column linkage. The cable allows you to route the cable around transmission, exhaust, cross-members and brake pedals. The Exclusive Billet Aluminum Mounting Arm can be used on either side of the column. Lokar's Column Cable Shift kit allows you to use the shift indicator kits. It can also be used in conjunction with the Back-Up Light or Neutral Safety Switch kit (BL-1400U) for most GM transmissions. It is available in black housing, designed with a specially extruded liner for extended life of the cable, and stainless inner wire measuring 6 feet in length. It has ready-to-install hardware and brackets included in the kit. There is no cutting or measuring as it simply bolts on. Longer cables are available upon request.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 09-11-2020, 06:38 AM   #2
derotoreut
derotoreut's Avatar
Re: Lokar ACA-1804 2" Column Cable Shift Linkage Kit
Sold
~ Dan
