Seat belt bolts
What size are the bolts for the seatbelts, that attach to the factory holes in the floor ?
Re: Seat belt bolts
DOT requires 7/16" UNF, or 1/2" UNC.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#3 | |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Seat belt bolts
I just looked at an old thread I posted and the stock holes I have are 7/16" fine thread. http://67-72chevytrucks.com/vboard/s...7&postcount=11 This is the type of bolts you use. Don't cheap out - https://www.julianos.com/Grade-8-7-1...p/ju010100.htm ![]() https://www.classicindustries.com/pr...oaAncvEALw_wcB https://www.opgi.com/interior-access...d-plated-1-14-
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 09-02-2020 at 07:35 PM. |
Re: Seat belt bolts
Apologizes for going OSHA, but can't over emphasize that the big @ss washer in Rocknrod's 1st link is what keeps the bolt from pulling through the floor should the vehicle comes to a violent stop. It takes little force to pull a single bolt head through sheet metal upon impact, so think of that washer as life insurance.
My truck ain't dead, it just smells funny. |
Re: Seat belt bolts
Just to add to ACK's point about using big arse washers when not using factory holes...Juliano's has an answer for that and I use them
https://www.julianos.com/Juliano-s-A...p/ju010600.htm |
#6 | |
Re: Seat belt bolts
My truck has the factory threaded holes in the floor, do I need nuts & washers under the truck floor as well ? |
Re: Seat belt bolts
No, factory holes are used with the bolts like Rocknrod posted.
Re: Seat belt bolts
Re: Seat belt bolts
My '66 had factory lap belts which were anchored with a shouldered bolt like the pic. That way the belt anchors could swivel a bit on the bolts. I personally would just go down to the hardware store and get a grade 8 bolt that fits and cinch them down tightly.
Moderator
Re: Seat belt bolts
Just to be clear they're called "shoulder bolts" because of the un-threaded larger shoulder below the hex hex. Not because they are used just on shoulder belts.
Re: Seat belt bolts
In short, if there's an anchor plate under the truck, most likely a rectangular piece of thick stamped sheet metal with a nut welded in the middle, you should look for 7/16"-20 x 1.25" bolts as mentioned above. As a side, the '64 - '66 shop manuals don't mention seat belts at all, however, I'm quite sure the assembly manual does. I agree with AcampoDave, grade 8 bolts are the way to go.
| Bookmarks |
