09-03-2020, 04:57 PM | #1 |
are 1960 cabs the same up to 1963'
As far as the cab, the 60, 61, 62 and 63 should bolt on to a 1960 frame? right
thanks guys |
09-03-2020, 07:14 PM | #2 | |
But Found Her 25yrs Later!
Re: are 1960 cabs the same up to 1963'
But the frame for the 63 is the same as 64-66. The 60-62 cab will bolt right up to a 60-62 frame, but the 63 cab has a different location for the front cab mounts. 63 front cab mounts are in the same location as the 64-66. But really, any of the 60-66 cabs will mount to any of the 60-66 frames, it just means drilling some holes.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-04-2020, 03:38 PM | #3 | |
Thank you "LostMy65", this info helps me out |
09-08-2020, 08:55 PM | #4 |
Any '60-'62 cab will mount on any '60-62 frame without modification
Any '63-'66 cab will mount on any '63-'66 frame without modification
'66 c10 rust bucket, 350 (pulled and sold, now waiting on 4bt install) nv4500 stock bellhousing, '85 c30 front suspension and 3/4 rear coils with 4.10 H072 rear axle NV4500 install http://67-72chevytrucks.com/vboard/s....php?p=6488778 Suspension update http://67-72chevytrucks.com/vboard/s....php?p=8236775 |
