Old 09-04-2020, 08:52 AM   #1
Suburban vs Longbed Frame
I haven't looked into this at all, yet, but thought maybe someone here would know if they are as comparable as I assume they are. I guess first question is wheelbase same or how different? What I am wondering about is if I could put a C3500 body on a K2500 Suburban frame. I know the body mounts will vary.
I found a rustfree '93 C3500 that came with a 6.5TD/4L80E. It was wrecked on the front left and the frame horn is bent. It only has the right fender and inner in place and motor/trans are gone.
I have a '95 K2500 Suburban with 350/4L80E, a clean frame, good front clip, and since I saw this wrecked truck for $600 it has me thinking. My Suburban has a crunched left rear quarter and the (sagging) driver door was damaged, fixed with a lot of bondo that has been messed up since I bought it. The dash is all messed up from the police equipment being cannibalized out of it. It also has a cracked windshield. None of this is all that bad, and I do like having a Suburban. I might try to find a nicer (fancier) cleaner Suburban to take it's place, then sacrifice the one I have for the truck. I'd like to buy the truck, either way, if not just for the rustfree cab, doors, bed, fender, and full-floater.
Old 09-04-2020, 10:36 AM   #2
b454rat
Re: Suburban vs Longbed Frame
Dunno where I read the build from, but someone was trying this very thing. Iirc the wheelbase is in between the burb n RCLB. Or if putting a flatbed on it wouldn’t really matter too much.
Old 09-04-2020, 05:46 PM   #3
Tom
driving is in my blood
Tom's Avatar
Everyone says you can't make/weld the cab and bed of a truck one piece because of twisting and what not. So something must be different for suburbans to be one piece and not flex to pieces.
Old 09-04-2020, 06:40 PM   #4
I think the difference there is the full top and pillars giving the body united strength. Also, there are doors to take up flex compared to a single slab from back of doors to tail end.
I've been told in the past that the vans use a Suburban chassis. I just remembered that. I wonder if there is truth in that. The conversation was over 4wd vans.
As far as wheelbase, I can look that up... Ok, just did. They are both 131.5". Vans are 135" and 155"It would be cool to have a pickup with the Suburban extra capacity fuel tank and skid plate, eliminate the truck tank, and run true dual exhaust, like you can on a Suburban
