09-04-2020, 01:36 PM | #1 |
Bilstein shocks
What Bilstein shocks are everyone running? I see that there are shock length charts online for 4600 series, 5100 series, 5125? What works best for a street driven truck?
I've been a Doetsch Tech guy before, but Bilsteins seem to come highly recommended and I figured I'd give them a try this time around. Thanks!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
09-05-2020, 02:03 PM | #2 | |
Re: Bilstein shocks
My '99 3/4 ton is getting stock replacement fronts & some replacement rears from my previous '90swb 1/2 ton. The rears were 'dropped truck' spec (per Bilstein chart) but when they came in they were OE length & just too short for the flip kit + shackle set-up. They would fit but compression stroke would have been non-existent. The '99 is similar but will not be dropped as much so I'll re-purpose those shocks for it. It's possible they would be the same p/n for both apps but I haven't looked it up/worried about it. For your Burb, I would just go w/replacements & if necessary tweak the mounting locations if increased travel is needed. I built upper relocation brackets for the front on my dually. Since the rear set-up on mine was swapped from leaf to 4-bar, I just used the replacement leaf-spring shocks in a better arrangement more suitable for the 4-bar/Panhard bar set-up.
