![]() ![]() Join Date: Jan 2005
Correct Fasteners for 67-68 Grille Center Support
A previous owner of my truck cut the center horizontal bar out of the grille and zip-tied a portion of a 71-72 grille in its place. I am in the process of returning it back to stock. The two smaller fasteners that attach the grille to the center support under the latch are missing. It looks like 1/4 or #14 screws would fit through the holes, and I'm assuming clip nuts need to be installed on the grille. I'd like to get as close to stock as I can. What size and type of fastener was on there originally?
Re: Correct Fasteners for 67-68 Grille Center Support
U or J-nuts on the grille support for sure. I used black hex head screws.
The problem with U or J-nuts is that the bend in the grille where the nut would go is too short for a standard J-nut. There must have been a very short clip on there originally. I guess I will trim down. A U-nut.
The J-nut goes on the center support.
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
https://www.lmctruck.com/1967-72-che...-for-chevrolet Pan down to the bottom of the page. Numbers 17 and 18 are what I believe you need...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#7 | |
