Old 09-05-2020, 05:18 PM   #1
truckster
truckster's Avatar
Brake Lines - I need pics
Please help me. I took my 72 Blazer apart seven years ago and I can't find my brake lines. I bought new lines, but I can't remember where they go. I've been able to find some pics on the site, but they all seem to be for 2WD vehicles. I need some pics for a 4WD - a K10 should be the same. In particular, I need to see how they descend from the proportioning valve, where they meet in front, and where they attach to the front brake hoses.
Thanks for your help!
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-05-2020, 08:06 PM   #2
gmc684x4
Re: Brake Lines - I need pics
The K10 run brake lines across the front riveted cross member unlike the C10 where it runs across the frame on the suspension cross member
Disc brake trucks have brake hose behind the bump stop where drum brake trucks have them before the bump stop
gmc684x4 is offline   Reply With Quote
Old 09-05-2020, 08:37 PM   #3
truckster
truckster's Avatar
Thanks you very much.
Would you have a pic of how the tee is mounted on the crossmember?
Also, I seem to be missing something. This is a picture of the AC Delco brake hose I bought, together with the retainer clip. I'm not even able to find a part listing for whatever is missing.
Old 09-05-2020, 08:45 PM   #4
gmc684x4
that clip goes inside the frame
Old 09-05-2020, 08:49 PM   #5
davischevy
davischevy's Avatar
You might look here. I won't be back aound my truck until Tuesday.
https://67-72chevytrucks.com/vboard/...d.php?t=755797
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-06-2020, 09:35 PM   #6
truckster
truckster's Avatar
I have the clips and the hoses. As the picture shows, the clips are too wide to clip on to the end of the hoses. I think there's a piece that goes on the end of the hose that the clip slides on.
Thanks. Those pics are very helpful. I was trying to run the lines from the proportioning valve inside the frame and now I see why it wouldn't work. I guess I'm going to need to order some brake line clips, because I can't find those either.
It looks like I'm going to have to go hit the wrecking yard for a couple of pieces I can't find online. That's what I get for taking so long...
Edit: Thanks! I got the lines in. I think Rock Auto sent me front hoses for a 2WD - they have a type of speed nut that holds them to the frame. I found some at the wrecking yard on a square body 2WD, and I also found the tee. I just need to find a union to join the rear line and I'll be done with this part of the build.
