Old 12-14-2003, 11:57 PM   #1
71swb4x4
71swb4x4's Avatar
Windshield washer pump won't work
OK my windshield washer pump isn't working. This is my fourth truck between 69-72, and none of them have had a working washer pump, so I am pretty sure this is a common problem. I would rather stay with the factory pump, and not one of the aftermarket add-ons if its feasible.
What is usually the problem with these factory ones? I have seen a rebuilt one in the LMC catalog. Will this do the trick for me?
When I push the switch in I can't hear any sounds. I got under there today and it looks like everything is hooked up properly.
This is my 3rd question in the last 10 minutes, not trying to hog the board, just had a long day in the garage -
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-15-2003, 12:01 AM   #2
mtdave2
newly minted old timer
mtdave2's Avatar
those rebuild kits work fine, they are just like the orginal. too bad the orginal one sucked! i have never seen a working one.
i always go with the aftermarket pump. works perfect, easy to put in. i am like you though, i do like to keep things orginal. almost everything on my truck is stock. 2 things though that i will always change, hei and a washer pump.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 12-15-2003, 12:26 AM   #3
dinnut
dinnut's Avatar
im trying to figure out where the lines go through the firewall to the washer pump from the lines in the cowl?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-15-2003, 01:16 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've seen one that worked. even though i was impressed with the fact that it worked...I was not impressed with the performance.
I'd say get an aftermarket one.
Old 12-15-2003, 04:01 AM   #5
1969 GMC
1969 GMC's Avatar
lol, i need one of those too...I am tired of having to grab handfuls of wet snow and wiping it on the windshield when I am stopped to clear the salt spray off.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-15-2003, 08:10 AM   #6
tom hand
CCRider
tom hand's Avatar
The problem with the factory pump, (besides being a poor design) is pumps are designed to push not pull. There is at least 4 feet of hose between the bottle and the pump. The pump is about the same height as the bottle so it does gravity feed very well, so the system usally needs to be primed if it runs dry. You can get the factory pump to work,but if you want a clean windsheild get an aftermarket one.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 12-15-2003, 10:43 AM   #7
krue
Designated A-hole!
krue's Avatar
I have a tank with the pump from a 92 s10 with the pump in the bottom of it. I want to use it for my washer and use my old washer bottle for an overflow tank. Will this work? Where can I get a cap for my factory washer bottle that I can connect a large enough hose for the overflow?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-15-2003, 11:28 AM   #8
racedvl
racedvl's Avatar
Check out what I wrote in this post. . . . .
http://67-72chevytrucks.com/vboard/s...threadid=78127
racedvl is offline   Reply With Quote
Old 12-15-2003, 11:32 AM   #9
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
before you go buying parts id check the wiring to it and the fuses the switch too lots of times its a wiring issue
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-15-2003, 11:44 AM   #10
Perchjerker
Beer Power!!!!!!!!!!
Perchjerker's Avatar
Hey, when I push the button on mine it makes a lot of popping and motor noises but no fluid comes out. I made sure water was coming through and also put one of those pump rebuild kits on it. What else could be wrong?
Rather be fishin'
Perchjerker is offline   Reply With Quote
Old 12-15-2003, 02:52 PM   #11
sukes84
i was lucky enough to find a NOS pump at a chevy dealer. i had tried a rebuild kit before, but the piston pump itself was shot. the new one works, but i will agree that it is nothing spectacular. guess its just one of the joys of 30+ year old technology.
sukes84 is offline   Reply With Quote
Old 12-15-2003, 03:05 PM   #12
mrein3
mrein3's Avatar
My washer pump has worked since the day I bought the truck. 10 years or so ago.
If you live where the temp can drop below freezing, NEVER put water in the reservoir. Always use the blue stuff. If you try to pump ice you'll ruin the pump.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-15-2003, 03:10 PM   #13
lukecp
Formerly yellow72custom
lukecp's Avatar
Mine worked for a little bit....only squirted out the driver's side nozzle though
Then one day it would turn on whenever the windshield wipers were on. I simply empted the resivour and forgot about it. When i replaced my wiper motor i didn't bother putting in a new pump....i'm used to not having a pump so ignornace is bliss
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-15-2003, 03:50 PM   #14
dropped_71chevy
Mine works but it if I use it then try to use my windshield wipers the pump keeps working til I shut down my truck
dropped_71chevy is offline   Reply With Quote
Old 12-16-2003, 01:54 PM   #15
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
WOO HOO!!! Now mine sounds like one of the better pumps...
It pops and clunks but nothing comes out. If I get a mouthful of water and blow it into the hose that connects to the tank while the pump is on, then I can get something out of it. So after I prime the pump, it will work, squirting short bursts of fluid. But if it sits for a few hours, then all of the fluid runs back into the tank.
Would a little rebuild kit for the pump solve this bad seal problem?!
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 12-16-2003, 02:04 PM   #16
photoglg
photoglg's Avatar
I had the same problem, made alot of noise but nothing came out. The problem was the clog wheel that works the pump it had broken off and the rebuild kits don't give you a new clog, I got one at the junk yard.
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 12-16-2003, 02:23 PM   #17
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I bought a pump from mother truckers and it works like has been said, I originally installed the LMC kit but it was the piston seal that was bad and would not pull the water.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
