![]() Join Date: Aug 2018
Van tilt, completely converted to to bolt in a truck and go
I have a pretty nice van tilt that I have converted to bolt in a truck with no modifications. It has the truck neutral safety, all new rubber gaskets, new turn signal stalk, new tilt stalk, used gear shifter but in real good shape, used indicator, a new gear pointer and the correct hazard knob. I completely disassembled this column and greased the bearings, steering knuckle at the tilt, and used red lock tight on the tilt mechanism bolts. Cleaned and greased the turn signal parts and painted it black. It also includes the intermediate shaft that has already been collapsed for a van tilt to work in a truck. The shifter pivot is nice and tight with no play. Pricing this at $350.00 plus actual shipping to the conus, Reason for the low price is it has a small run on the bottom of the column that I will picture and will not be seen. Pics to follow. SOLD
Re: Van tilt, completely converted to to bolt in a truck and go
More pics
And a few more
Ttt
Active Member
![]() Join Date: Mar 2016
Pm seen
![]() Join Date: Oct 2012
Hello.....what is the diff between a truck and van column. Im assuming one is shorter?
Thanks.
72 Cheyenne Super 350 Holley EFI/700R4 67 Camaro SS/RS 68 Corvette 427 Tri-power 4-speed convertible 55 Chevy Belair Hardtop |
Active Member
Just give a call please 865-250-3628
Sale pending to Hotrod1972GH
![]() Join Date: Jan 2007
Nice set up
#13 |
![]() Join Date: Jun 2005
i will get in line behind hotrod pending shipping cost to 95356. thanks
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
#14 |
Sold to Hotrod1972GH. Thanks.
