Old 09-06-2020, 09:39 PM   #1
ngnaz
Newly purchased, Lift and steering question
I picked up this 72 Blazer and it has awful steering and suspension. I am trying to determine what I have and where to start. Not sure of the lift size or details and was wondering how I measure it to find out. Here are a few pics. It looked like it had dual shocks front and rear but the fronts are missing. Not even drive-able as it wanders so much. It has Skyjacker shocks and also a dual skyjacker steering stabilizer. Tires are 33x12.50x15 Thanks
ngnaz is offline   Reply With Quote
Old 09-07-2020, 10:54 PM   #2
truckster
truckster's Avatar
Re: Newly purchased, Lift and steering question
It looks close to stock height to me. I should have my wheels back on tomorrow, and I can give you a height measurement then - I also have 12.5x33 tires.
As far as the steering, having shocks would definitely help. I would take a look at the steering gearbox and the rag joint, plus all the usual suspects like ball joints and tie rod ends.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-08-2020, 07:55 AM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The rear spring looks stock - the height of the block under the spring pack should give you an estimate of the lift.
Old 09-08-2020, 08:20 PM   #4
truckster
truckster's Avatar
I totally missed that.
Old 09-10-2020, 01:17 AM   #5
Tmend
Tmend's Avatar
Stock hight is 21 3/4 on rear and front is 22 3/4 inches. Measure from center of hub to center of arch on wheel well. Whatever you get just subtract.
Some progress is better then no progress
Tmend is online now   Reply With Quote
Old 09-11-2020, 07:56 AM   #6
hemi43
hemi43's Avatar
There's tons of pictures on here with ride height measurements. I probably posted 10 of them. Do a search.
edit; here's a link with measurements----> http://67-72chevytrucks.com/vboard/s...d.php?t=754525
hemi43 is offline   Reply With Quote
