09-07-2020, 05:24 PM | #1 |
Dome Light Wire Routing
Ok, I'm probably over thinking this but I am trying to run a new dome light wire. The old wire is gone so I can't use it to pull the new wire though. Nor do I have any idea how the wire was routed from the factory. I have managed to get a line run from the dorm light opening to the driver side cab corner. If I go down I can run it in the floor/inner rocker channel. But then where would you run the wire from there once you get to the A-pillar?
I have been trying to fish the wire in the roof above the drive side door opening but haven't been able to get it through. Which way should I be trying to run the wires?
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
09-07-2020, 08:46 PM | #2 |
Junior Member
Re: Dome Light Wire Routing
Just bought a new light but haven't put it in yet. Assuming my 72 is the same, your first instinct was correct. From the center to the upper cab corner, down the B pillar, under the kickplate to the connector which is under the carpet I think near or on the firewall. If you have the correct reproduction light, you should see the compatible connector somewhere on the floor.
09-07-2020, 10:55 PM | #3 |
My new light does not have a connector on it. It has just the two wires and about 6-8 feet of wire.
I have been trying to fish the wire up the A-pillar but no luck there. I can get it up to the roof line and no furher. Same thing going from the sun visor hole to the rear cab corner on the drivers side.
09-08-2020, 12:28 AM | #4 | |
20' Daredevil (Ret)
09-08-2020, 12:29 AM | #5 |
you are over thinking it. It runs from the dome light hole down to the cab corner and along the inner/outer rocker as you stated. From there it just runs under the carpet to the fuse box. Or at least that is the way mine is run.
09-08-2020, 08:02 AM | #6 |
Thanks for confirming that I was over thinking it. That will make running the wires a lot easier AND less stressful.
09-08-2020, 09:32 AM | #7 |
Use a metal wire snake to get the wires up to the dome light, just did it yesterday works like a charm.
09-08-2020, 09:55 AM | #8 |
Mr. Cheyenne
@Tripmiester - where did you start the wire snake wire from? I assume from the driver side floor (behind the drive side seat)?
Edit: I am asking since I need to run a new wire for a Cargo Brake Light, as I'll be installing a new Cargo Light that has LED Whites and then Reds for breaking. I believe the wires going into the Dome, piggyback off to the Cargo light - thus running a break line I think I follow the dome light path.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 09-08-2020 at 10:07 AM. |
09-08-2020, 06:02 PM | #9 |
At the dome light I just added a cargo light as well
09-08-2020, 09:05 PM | #10 |
Where did you get a cargo /Brake light?
09-08-2020, 10:37 PM | #11 |
Mr. Cheyenne
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
09-10-2020, 10:15 AM | #12 |
Old member
Here is my thread on doing this. I used a old drop cord to fish the wires through. Ground the wire anyplace that is convent and run the hot through the gutter up to the front of the truck under the carpet and tie into your fuse that has the lights labeled.
http://67-72chevytrucks.com/vboard/s...d.php?t=790874
09-10-2020, 11:10 AM | #13 |
Mr. Cheyenne
I have a Kline fish wire to help me with this thank you for your information!
