![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
11 inch clutch kit for T5 swap
In looking through threads for T5 swaps I thought someone had listed a part number or an application for an 11 inch clutch kit for use in our trucks when using the S10 T5. However I am now not able to find it again. If anyone could help me out with this it would be greatly appreciated.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris Last edited by 67 twins; 09-10-2020 at 10:57 AM. Reason: I'm an idiot |
![]() Join Date: Aug 2004
Re: 11 inch clutch kit for T5 swap
From my research, a big block 70s Vette should fit the bill.
I’ll be using the same for my 6.0 + TKO and that’s what I came up with.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
The Older Generation
I completed the S-10 install in my '67 with a 250 six cylinder a few years ago. It works great! I purchased the spacer plate and used the '85 Astro van 11" clutch disk. I didn't have to use the adapter ring in the bell housing locator hole, the SM420 bell housing was the right size for the S-10 front bearing retainer. Here is where the shifter is in relation to the bench seat. I bent the shift lever straight up from where the sharp bend was and it worked pretty good. It isn't as close to the dash as it looks. The shifter on it now is off of a full size pickup 5 speed and it is too big to screw on the shaft and too long. I just slid it down over the shift lever so I could test drive it. The yellow circle shows where the original shifter hole was and the new hole is about 8-1/4" back. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-11-2020 at 10:22 AM. |
![]() Join Date: Oct 2009
here's the thread on my swap. I also used an Astro van 11" clutch kit.
http://67-72chevytrucks.com/vboard/s...d.php?t=482069 |
How much is the spacer plate and where did you buy it? I'm trying to save money on this install. My plan was to shorten the input shaft pilot area & front bearing retainer to provide clearance
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
#6 | |
I read that some guys shortened the input shaft and bearing retainer but I didn't want to go that route. A couple of guys even used big washers at each bolt location to space the transmission back from the bell housing but I wouldn't recommend that. The company I bought mine from is no longer in business. I think I paid $43 for my spacer plate when I bought it.. Here are some and there are others with many different prices. Do some more searching. Hot Rod Works Spacer: https://www.hotrodworks.com/product/...ssion-adapter/ ----------------------------------- Speed Gems https://transmissionadapters.com/col...ducts/mt100010 ---------------------------------------- Davis Speed Equipment: https://davisspeedequipment.com/prod...-spacer-plate/ Read the sites instructions carefully. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-11-2020 at 10:13 AM. |
Post Whore
![]() Join Date: Feb 2016
One piece of advice I can't emphasize enough is to make sure you dial in your bell housing to make sure everything is aligned before you bolt it all down for good.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#8 | |
Re: 11 inch clutch kit for T5 swap &
In your first post you say it fits the SM465 bellhousing don't you mean SM420.
I'm not sure what you mean by dial in. The bellhousing locates to pins in the engine block. The transmission centers to the hole in bellhousing. What else is there to do?
Dialing in a bell hsg is checking, and correcting if necessary, how well the stock dowel pins center the bell housing's opening relative to the crank centerline before the trans is installed.
Here's how you do it: https://www.moderndriveline.com/prop...ment-indexing/ Here's how you fix it if you find a problem: https://www.summitracing.com/search/...20dowel%20pins Most do not do this - and most won't have a problem if they don't - but it is a good safeguard against mass production tolerances, casting defects, etc. |
Dialing in the bellhousing is a little pain, but is worthwhile on a performance application.
Cheap feeler gauges can be cut to shim the bellhousing face parallel to crank and I like the Robbmc adjustable dowel pins. The Lakewoods are similar, but the Robbmc are 75% less money and work great. https://www.robbmcperformance.com/products/dowels.html
#12 | |
You are right on the SM 420, it would have the smaller hole. I was thinking about the NV4500 install in my '72 C30 which had the SM465 transmission & 5 1/8" hole for the bearing retainer. Thanks for spotting that. I will go back and change it. LockDoc
#13 | |
Post Whore
When you are using a group of parts that didn't come from the factory together and were manufactured with different tolerance standards the odds for failure go up. Over the decades companies change how they do things. Not every 3/8 alignment pin and hole is set up the same. For example are the holes in the 67 bell housing 0.375 and the engine pins 2 or 5 thousands undersize to allow for manufacturing tolerances? Or are the pins exactly 0.375 and the holes oversized to compensate for any oversized pins? Did GM use the same procedure on vehicles manufactured in the 1990's? Is the T-5 pilot a metric equivalent of a fractional pilot? Too many variables that cause expensive heart aches for my peace of mind. https://www.hotrod.com/articles/ctrp...ing-alignment/ https://youtu.be/3ngXGrg6Y1s
#14 |
I'd be hunting down an Astro van clutch if that is what I planned to use. They are all but impossible to find. I think I got the last Astro van 11 inch clutch disk that Rock Auto ever sold for my OT hot rod. That was five or six years ago and they have become harder to get since.
The simple solution if you have a WC S 10 T 5 is to swap in a Jeep input shaft that lets you use a regular 10 spline Clutch disk. https://lugnutz65chevystepside.weebl...ter-plate.html They are usually on Ebay for 70 something $$ New.
#15 | |
I did mine a few years ago too but I got my disk through NAPA. They had to order it but didn't have any trouble finding it. LockDoc
#16 |
[QUOTE=mr48chev;8806630]I'd be hunting down an Astro van clutch if that is what I planned to use. They are all but impossible to find. I think I got the last Astro van 11 inch clutch disk that Rock Auto ever sold for my OT hot rod. That was five or six years ago and they have become harder to get since.
The simple solution if you have a WC S 10 T 5 is to swap in a Jeep input shaft that lets you use a regular 10 spline Clutch disk. https://lugnutz65chevystepside.weebl...ter-plate.html They are usually on Ebay for 70 something $$ New.[/Q Not a problem, Rock Auto lists 7 different clutch kits for this application. I just ordered one from my local O'Reilly's
#17 | |
It's obviously been done with a different clutch however. We bought my wife's truck with a T5 already installed with no spacer involved. I don't know what clutch it has installed, but I can tell it's a much smaller clutch. I imagine it's probably the 9 1/8 inch clutch from an S10.
