Old 09-09-2020, 07:26 PM   #1
rockyrivermark
Time capsule non c10 quadajet question
Got a question on a non c10. Hope that’s ok but the carb is a very similar Quadrajet that’s used on our C10’s. So much knowledge on this board I thought this would give me good info as it usually does.
1986 el Camino
14,000 miles
The idle is a bit high and even with cables pulled off the carb it won’t return to idle stop unless manually turned back and has a bit of resistance.
More resistance than just new return springs will cure
Gonna dig deeper and check choke side and high idle set points but choke was fully open at idle.
Obviously the car sat in storage for extended periods but usually driven a bit year year.
it’s dads car/truck and some health issues kept him away for 3 years.
Is there something I should look for or a common problem that occurs with this symptom? I did WD40 on moving parts but didn’t help
Any advise or info appreciated.
RRM
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 09-09-2020, 07:39 PM   #2
geezer#99
geezer#99's Avatar
Re: Time capsule non c10 quadajet question
I had one that someone had removed the primary throttle shaft to re-bush it and when they installed the plates back on the shaft they didn’t get them centered equally. One side hung up on the bore enough to cause an elevated idle.
Had to loosen the staked screws and re-centre both.
Good looking ride!
Your dad’s got style!
Old 09-09-2020, 07:45 PM   #3
dmjlambert
dmjlambert's Avatar
Great looking truck! Can you post pictures of the carburetor please?
dmjlambert is offline   Reply With Quote
Old 09-09-2020, 07:54 PM   #4
rockyrivermark
I’ll get carb pics ASAP. One owner vehicle so nothing was tampered with.
RRM
My build page
Old 09-09-2020, 10:05 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
If bushings have not been installed, Geezer#99 still has a line on the probable cause, it's just that the carburetor base plate may be the culprit. This is a very common problem. Spritz some carb cleaner on the primary throttle shaft (both sides) and see if the idle changes. If it does, that's likely the problem.
~Steven
Simi Valley, CA
Old 09-10-2020, 12:37 PM   #6
54blackhornet
54blackhornet's Avatar
Beautiful ELCO ! I worked at a Chevrolet dealership in CT when these where new. We sold a ton of them, mostly maroon. The Cho Cho SS conversion was very popular.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 09-10-2020, 06:19 PM   #7
rockyrivermark
I stopped there today and backed off the choke. Idle back where it belongs when it’s warmed up. All good.
RRM
My build page
