Old 09-10-2020, 04:03 PM   #1
cfan10
cfan10's Avatar
Cool Will these wheels fit?
Ok, I've been in love with these for years, finally found a decent affordable set but the guy doesn't really know if they will work.
'85 C10 swb 5 lug
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 09-10-2020, 04:07 PM   #2
cfan10
cfan10's Avatar
Cool Re: Will these wheels fit?
These are my grail
Old 09-10-2020, 04:19 PM   #3
cfan10
cfan10's Avatar
Thank you for your time it is greatly appreciated.
Old 09-10-2020, 10:33 PM   #4
I think those may be the smaller 4.5" or 4.75" bolt pattern. Since those are unilug, you must measure between similar bolts holes. Hard to tell, but for five lug they won't be across the center like that. I have a couple little disk templates that I carry with me to tell me what they are.
Old 09-12-2020, 02:35 PM   #5
f.monroe
f.monroe's Avatar
Those holes are part of two different patterns on those wheels. Look like they are 4.5 and 4.75 to me .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 09-13-2020, 04:26 AM   #6
cfan10
cfan10's Avatar
Thanks to everyone who shared the info I needed, wish these would've worked the search continues.
Old 09-21-2020, 09:53 AM   #7
Pontiac1976
Pontiac1976's Avatar
Try taking used cardboard big enough cover your hub on the spindle lightly tap so the lugs in boss the card board cut out the in bosses in the out area of the mounting face, take that with you. Place on the wheel line up the holes if it does not line up with all the hole that rim will not work.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-21-2020, 11:51 AM   #8
When you deal with lots of junkers and junk wheels, these are handy to have around.
https://www.ebay.com/i/183803603052?...EaAjIxEALw_wcB
