71 k10 rear leaf spring anti-squeak pad?
Hi everyone,
frame up rebuild on a 71 K10. Rear leaf springs on one side had these in-between. i'm assuming to avoid squeaks when the leafs move. where can i get these? and should there be one in-between all leafs? |
Re: 71 k10 rear leaf spring anti-squeak pad?
You could probably refine the search.
https://www.google.com/search?client...af+spring+pads |
Only one per spring pack was used. You probably want factory correct, but the springs don't squeak w/o them.
I would look at new springs on a restoration
Even on a babied truck more then 48 years There will be a fair amount of sag on the springs Really evident on trucks that people use lift blocks in the rear |
