Old 09-12-2020, 09:08 PM   #1
Phuloi68
Body swap
Can any one tell me if a 1993
cab can be mounted on a 81-87 frame? Possible? Difficult?
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
for those who fight for it...
F R E E D O M
has a price the protected
will never know.
Phuloi68 is offline   Reply With Quote
Old 09-13-2020, 02:45 AM   #2
SCOTI
SCOTI's Avatar
Re: Body swap
Anything is possible w/the right talent & execution.
Why are you wanting to do the '93 cab/81-87 frame? What is your goal?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-13-2020, 04:22 AM   #3
cfan10
cfan10's Avatar
Cool Re: Body swap
I would rather have the '93 frame under the square those frames are sturdy and less prone to the gearbox crack. Which square body's are notorious for.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 09-13-2020, 07:37 AM   #4
Re: Body swap
AS mentioned, it isa possible, but lots of work. Also, remember the 88-98 models have a slightly longer wheel base then the squares do. If I remember right it is 1 or 2 inches. Not sure how it would effect totally, but the steering box for the 88-98 mount tyo the inside of the fram, so I am not sure how that will be for your steering column alignment.
Old 09-13-2020, 01:58 PM   #5
sweetk30
sweetk30's Avatar
Re: Body swap
and the frame gets wider as it goes to the back end . so think of it as a peice of pie /\ . makes it a lot harder . and the overall width to start with is massive if i recall its 10" wider under the cab area over our older trucks . lots of stuff went inside the frame rails on 88-up gmt-400 trucks .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-13-2020, 09:11 PM   #6
Phuloi68
Re: Body swap
I was asking about the possibilities of this swap as there is a rust free 93 cab available at a good price.
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
F R E E D O M
will never know.
Old 09-13-2020, 09:18 PM   #7
Re: Body swap
The square frame kickup (For fuel tank) will require chopping out and reworking the floor to sit on the frame, among other stuff.
Old 09-13-2020, 09:53 PM   #8
Phuloi68
Re: Body swap
It was just a thought. Don't need the headache if it is difficult to do.
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
F R E E D O M
will never know.
Old 09-13-2020, 10:27 PM   #9
mr48chev
mr48chev's Avatar
Re: Body swap
I'm thinking that the 88 and up gas tanks are at the rear between the frame rails rather than the outboard of the frame tanks on the squares. Remember all of that ruckus about the tanks of the squares splitting open if you were broadsided?
Square tread is noticeably wider than 88 and up too I believe but you can get that Goat roper deep reverse wheel look without deep reverse wheels.
It doesn't matter what frame swap you do there are no free lunches in frame swaps. You are always going to have a challenge or spend an exobitant amount of money for a kit to make it easy.
My ongoing truck projects:
Old 09-13-2020, 10:32 PM   #10
SCOTI
SCOTI's Avatar
Re: Body swap
88-98 have wider frames & wider track widths.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-14-2020, 11:11 AM   #11
1976gmc20
Re: Body swap
But the body is narrower.
I'm no expert but I have one of each sitting out here side by side. I have measured the body widths but not the track widths. The wheels are vastly different in back space, so if the axles are wider then that is wholly or partially offset by the difference in the wheels which sit more inboard on the 88-98.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 09-14-2020, 12:03 PM   #12
SCOTI
SCOTI's Avatar
Re: Body swap
Correct. Axles & front track width is wider by 1.5" on the 1/2 tons if I remember correctly. Back spacing on the wheels is different as a result.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-14-2020, 12:16 PM   #13
Re: Body swap
They are still in the same side location, just inside the frame rail. That was the main reason for the change, all the lawsuits for socalled explosions of the tank on the outside of the side rail.
Old 09-14-2020, 03:10 PM   #14
1976gmc20
Re: Body swap
I learned this stuff very painfully from trying to adapt GMT400 6-hole 16" wheels to a square body 4x4
