![]() Join Date: Apr 2013
Differences in bell-cranks between trucks with 6 cyl and 8 cyl engines??
I have a person wanting to purchase a frame to engine bell-crank for a 427 v-8 with 4 speed transmission he is installing in a 67-68 C10. Anyone know what this part should look like?? I have a couple or three, but not sure what they fit.
Any help / pictures would be appreciated! Jay
PayPal 1windyridgeboy@gmail.com Last edited by Clatterville trolley; 09-12-2020 at 09:22 PM. Reason: Left out some of explanation. |
#2 | |
The Older Generation
Re: Differences in bell-cranks between trucks with 6 cyl and 8 cyl engines??
I'm going to follow along on this one. I have a lot of different styles but I don't know what they fit either..... Post up some pictures if you can. Bump for you. LockDoc
I am going to say same one as a small block bell crank
The strait 6 ones are different i dont rember fully in what way been a long time since i had a 6 banger https://www.brotherstrucks.com/67-72...tinfo/BLC6772/ |
Here is a couple of pics from the V8 one from my 72
You can measure the distance from the frame rail mount to the engine block as a double check that you can drop a big block and a small block on the same frame perches tells be it will fit All 67 72 K series trucks use the back mount position it is only in the C models that they move the engine front or back depending on 6 or 8 cylinder When I start putting my C10 together I will keep the motor back make room for the long water pump and serpentine belt setup When I talked to My Late cousin before he passed last month about his 69 with a 396 he kept the motor in the back position as well for better header room Last edited by gmc684x4; 09-12-2020 at 11:00 PM. |
![]() Join Date: Jul 2001
No authority by any means but I thought the BBC bell cranks or Z-bars were different than the SBC which is different from the IL6.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Thanks for the input and photos with measurements!! If I remember correctly the pivot that bolts to the engine that this crank swings on for 6 cylinder is much taller? / longer than the one that a small block uses. But just can't remember on crank differences.
Also thought maybe because he was using a 427 that the crank would be entirely different or not?
PayPal 1windyridgeboy@gmail.com Last edited by Clatterville trolley; 09-12-2020 at 11:02 PM. Reason: left out words |
You should be able to find one here.
At least an idea what you need. They might even have an answer for you. https://www.4speedconversions.com/se...?keyword=Z+bar |
#8 | |
PayPal 1windyridgeboy@gmail.com |
I can measure the one in my Green '67 in the morning, it has a 250 I6, and the '72 Dually, it has a 350 with the SM465 linkage in it. I will take pictures of the other ones I have for reference also. LockDoc
![]() Join Date: Feb 2002
L6 Z-Bars have to be longer. The L6 block is skinnier than the V8.
Isn't the pivot point that bolts to the block longer too on L6 to help make up the distance? Jay
Six banger had a bracket similar to this to make up the distance.
Truck one was slightly different. https://www.ebay.com/i/153926914679?chn=ps V8 had a pivot ball that screwed into a threaded hole in the block. |
#13 | |
On my L6 truck --'68 C/10 Stepside, w/292, there's a ''U'' bracket that extends 4'' and then the ball stud pivot extends from there.
#14 | |
#15 |
![]() Join Date: Dec 2013
Here are a few 6/small block the 4th one down is for a small block IIRC and alignment of pivot plate on small block.
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#16 |
Thanks for input and photos Grumpy!
#17 |
Looks very familiar.
#18 |
Thanks for everyone's input and ideas!! Jay
