Old 09-14-2020, 08:58 AM   #1
bean
Windshield install question
Tried over and over again yesterday to install windshield in my 72 but no luck. Couple of questions... Which is easier starting at the top of the bottom? Secondly what have you guys used for lubricant? I tried soapy water as well as glass cleaner but in this texas heat both seem to dry really fast. Seemed like my biggest struggle was getting the glass centered in and the windshield wouldn't move much. Anyhow any and all help is appreciated.
bean is offline   Reply With Quote
Old 09-14-2020, 09:50 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Windshield install question
This is going to be short & sweet since you already know the basics, and not everyone is going to agree with me.
First off you need at least one helper and preferably two for the installation.
I always set the bottom in first so the weight of the glass holds it in place over the pinch weld. Yes, this makes the top corners a little harder to get in place but overall makes the whole process easier for me. In the heat you will need to use Vaseline or something similar that doesn't dry out for a lube.
Everybody does it different, but I have installed quite a few windshields, with used and new gaskets, and with and without the trim, and never had much of a problem.
LockDoc
Leon
Old 09-14-2020, 12:01 PM   #3
bean
Thank you lockdoc!
Old 09-14-2020, 01:37 PM   #4
gmc684x4
If you have two helpers both can help keep the glass pushed up if you put the top in first that is how we did my windshield last month
We did that since i didn't want to fit with the square corners
gmc684x4 is offline   Reply With Quote
Old 09-14-2020, 02:15 PM   #5
RenoKeene
Florida Edition
RenoKeene's Avatar
My experience is if you have the gasket with trim start from the top down as the corners are the hardest like LockDoc said. Without the trim work from the bottom up. The trim is a notorious pain to get right, many, many threads on here you can reference.
Good Luck.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 09-14-2020, 02:46 PM   #6
bean
It sounds like or bottom first is really more a matter of personal preference. I think I will try the vaseline idea and try bottom first can always switch if first time doesn't work. When I put the sliding window in back that s how I did it and it was pretty easy. We 'll see what happens. Thank you for your responses.
Old 09-14-2020, 02:47 PM   #7
Bowler1
I hope you are using a cotton rope in the pinchweld pocket that makes it a lot easier. I installed windshields for 30 plus years have rope start at bottom middle start bottom first that is one of easiest windshields to install.
Bowler1 is offline   Reply With Quote
Old 09-14-2020, 04:24 PM   #8
bean
Thank you
Old 09-14-2020, 04:37 PM   #9
Putzer
Had a heck of a time installing mine. I tried with my ole lady helping me and it didnt go well. Had my buddy come over and we had it installed within 20 mins. Need to keep pressure the entire time with open palms from outside. Set bottom first.
Putzer is offline   Reply With Quote
Old 09-15-2020, 01:24 AM   #10
Richard
Just did my 72 w/trim on Sunday. My wife helped me set it on the window opening and did the rest myself. An FYI, petroleum based lubricants are generally not recommended. Use window cleaner if you want lubricant. Did mine dry. Used a hook tool, rope and two nice pump up suction cups for glass. Pulled top edge in first, then sides. Moved suction cups to inside window to pull window in and up as I worked bottom into place. Fought me a bit. Though it has been a long time since I did one.
Richard
Old 09-16-2020, 09:30 AM   #11
72bowtiestepper
Going to try to do my 72 without trim soon....is it easier when the temp is warm ? Thanks for the tips already posted. The videos I have seen said start at the top...seems the bottom would be easier.
72bowtiestepper is offline   Reply With Quote
Old 09-16-2020, 10:36 AM   #12
LockDoc
LockDoc's Avatar
Higher temp makes the rubber seal more pliable and easier to work over the pinch weld.
LockDoc
Leon
Old 09-18-2020, 09:32 AM   #13
72c20customcamper
72c20customcamper's Avatar
Always started on the bottom 2 guys outside one inside working the rope for lube we used Ru-Glyde rubber lubricant. In winter we would heat the rubber with heat lamps prior to install .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 09-18-2020, 09:43 AM   #14
72bowtiestepper
Thanks a bunch Lockdoc & 72customcamper !
Old 09-18-2020, 10:16 AM   #15
68 P.O.S.
Precision has a good video on YouTube where they show how to install one in our trucks.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 09-20-2020, 05:10 PM   #16
68 P.O.S.
https://youtu.be/SOU_0HpS7To
