09-14-2020, 02:04 PM | #1 |
K30 Axle Transplant or Frame Swap
Hey guys,
I am looking at swapping my 67 c30 over to 4x4. I am curious does anyone have experience with this? Is it better to transplant a dana 60 under my c30 frame or is it better to Get a 73-87 K30 frame and do a body swap? Thanks in advance! |
09-14-2020, 02:15 PM | #2 |
Re: K30 Axle Transplant or Frame Swap
Square body frame swap (in my opinion) would be more work than putting a front end under the existing frame. But I've been doing conversions for over 30 years. Is your 67 frame dented in at the steering box?
09-14-2020, 03:13 PM | #3 |
kwmech,
Thank you for the reply! I believe my frame is not dented for the box, but I would need to look again. If it is dented, I will have to patch this with flat steel correct? |
09-14-2020, 03:26 PM | #4 | |
All about them K’s
http://67-72chevytrucks.com/vboard/s...=703160&page=6 This thread might give you an idea about what it’ll take to get the front axle under it. There are others like it on here too.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 09-14-2020 at 03:38 PM. |
09-14-2020, 06:00 PM | #5 |
Are the k30 spring mounts different then say the k10
I have a chance to get a 70 c30 gmc and thinking of things to do with it In the land of ice and snow a heavy 2 wheel drive is not as useful |
09-14-2020, 06:54 PM | #6 |
All about them K’s
67-72 4x4 and square body K30 use the same spring perch width front and rear. 1/2 and 3/4 square body rear perches are not the same as 67-72. Square body front axle perches are the same width as 67-72 4x4. Clear as mud??
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
09-14-2020, 07:02 PM | #7 |
SWB 4x4 Collector
I converted my C30 frame to 4x4. Its pretty simple if you can locate the 4x4 brackets.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
09-14-2020, 08:27 PM | #8 |
Yep. Pretty darn easy. Almost plug and play. Definitely the way to go
09-15-2020, 02:03 AM | #9 |
Did you bolt the spring perchs on with 7/16 grade 8 bolts ?
I have a line on a c30 running truck been decideing on what could do to it A 70 gmc 1 ton dually 4x4 would be a good project for it a spare sm465 with 205 tcase a spare 69 k10 chassis 8 bolt dana 44 and dana 60 rear i guesing the rear in the c30 is a dana 60 |
09-15-2020, 11:32 AM | #10 |
09-15-2020, 05:59 PM | #11 | |
All about them K’s
A paid subscription and a want to buy add on the parts board will likely get you what you need. Off road design and others have fabbed front hangers that can likely be made to work but won’t be as easy as the oe offering.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 09-15-2020 at 06:05 PM. |
09-15-2020, 10:03 PM | #12 |
SWB 4x4 Collector
I have collected parts over the years or 4x4s destined for scrap. I robbed 4x4 brackets from my parts stash and drilled and bolted them to accept the next size up grade 8 bolts. This truck was originally a 72 C30 chassis.
09-16-2020, 06:55 AM | #13 |
You can use spring brackets from any GM 4wd frame, from Blazer up.
09-16-2020, 08:18 AM | #14 | |
If you need any further assistance with that please contact any Admin for help. Last edited by LockDoc; 09-17-2020 at 09:51 PM. |
09-16-2020, 10:41 AM | #15 |
SWB 4x4 Collector
I only have one spare set left, and I am contemplating using them on a longhorn frame I have to make a K30 Dually.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever Last edited by LockDoc; 09-17-2020 at 09:52 PM. |
09-16-2020, 11:02 AM | #16 |
09-17-2020, 06:41 PM | #17 |
How do you find where the rear of the front leaf spring mount should be located?
09-17-2020, 09:19 PM | #18 |
SWB 4x4 Collector
I measured from the radiator support bracket to where it landed on one of my 4x4 frames. I may have also measured from the front cab mount as well. The 67-72 Chevy 4x4 brackets are made to sit on the inside of the frame rails, so really, you just need to locate the bushing hole.
09-17-2020, 09:49 PM | #19 | |
