Active Member
![]() Join Date: Nov 2018
Inner Wheel Arch
Does anyone know if there is an inner wheel arch repair panel available for a fleetside? Specifically, I have rust where the where the wheel well bolts to the bedside.
#2 | |
The Older Generation
Re: Inner Wheel Arch
I don't know of a repair panel for that area but I think it is pretty flat so maybe a guy could just make one from scratch. LockDoc
made my own as they don't make re pops. I raised the mounting bolts up 2" for a raised bed.
Do it, Do it right, Do it right the first time |
yes they are available. most of your good parts supplier will carry them
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
Thanks, good to know they are available. LockDoc
If you buy a complete bed from a vendor, is this part of the bedside? Or a separate item?
![]() Join Date: Mar 2000
We have had these for at least 5-6 years now possibly longer.
Part # 6682895-2 67-72 Fleetside, Blazer, Jimmy Inner Bed Side Wheelhouse Flange ![]() Found on the following page of our website. https://gmcpauls.com/bed_patch_panels.htm We have a ton of new parts that are now also that should be added to our website in very near future such as all styles of inner cab rear window panel, complete inner cab roofs, complete B-Pillars for 67-70 drivers side and b-pillar for 71-72 drivers side with pressure relief valve opening which didn't exist in 67-70, 67-72 passenger side b-pillars, driver and passenger side roof rail weatherstrip channels for joining a & b-pillars at top of cab to inner and outer cab roof. 67 Inner Upper Cab Back Wall W/Small Rear Window ![]() 67-72 Inner Upper Cab Back Wall Large Rear Window ![]() 67-70 And 72 Inner Roof Complete can be used on 71 also nut no raised mirror pad like original on 71 only. ![]() 67-72 B-Pillar Passenger Side ![]() 71-72 B-Pilla rDrivers Side ![]() 67-70 B-Pillar Drivers Side ![]() 67-72 A-Pillar To B-Pillar Roof Rail ![]() 67-68 Firewall Toe Panel With Air Conditioning ![]() We also have a lot more new items to add and more coming soon. Paul Jr @ GMCPauls Last edited by GMCPaul; 09-19-2020 at 01:37 PM. |
#9 | |
Paul Jr @ GMCPauls |
Active Member
Awesome, thanks for the info. I'll be checking them out for sure.
