Young Gun wth Fast Inline
Huck, a solution for you
Huck, i was looking on paces site. heres a speedo conversion that will for you or anyone else for the matter. It takes a electronic signal from your tranny and then runs a speedo cable that will work in our trucks.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
Forgot the link.... here t is http://www.paceparts.com/product.asp?3=166918
I know that the 700r4 trans was made with both mechanical and electronic speedos, so the parts are available for the conversion for the automatic. I have also replaced the speedo gear with a shudder wheel in a np205 tcase swap I did. The inside splines are exactly the same, so it was a dirrect swap. My point is, see if the trans you are running was produced prior to the electronic speedo ('87 and down I think). Even if not, the sensor ring will probably be a dirrect swap with a speedo pickup gear. Then you would need to modify the tailhousing (if it has one) to accept the speedo cable. It helps if you know a machinist for this. It may be cheaper than $280
1957 Cameo |
huck is using a nv4500. they dont any provisions for a mechanical hookup. He hasnt been able to find out how to get his speedo to work yet.
This site shows what I mean
www.autotransinc.com/ 4l80hous.htm
1957 Cameo |
1957 Cameo |
