Engine dies in gear ?
I have a 71 C10 with a 350/350 combo . Engine is original with a quadrajet but runs O.K. The problem is is that I can start it and let it warm up for a couple of minutes and when I attempt to put it into drive or reverse it stalls . It will re-start right away but until it is really warmed up it does the same thing . Is it that the motor is so shot that it doesnt have enough poop to keep going or something else ?
Re: Engine dies in gear ?
Have you tried to turn the idle up some. My old 85 will do the same thing. Its got a pretty tired motor in it. I just turn the idle a bit, but not so much that it kicks hard into gear. I try to find the happy medium.
Other things that I have known to cause this kind of behavior is vacuum leaks and bad timing.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
Lack of enough initial timing does that.
What’s your initial timing set at? Or sometimes a cold intake does too. Do you have headers? Or poorly adjusted choke. Does it work well? |
![]() Join Date: Mar 2005
Welcome to the world of non computer controlled FI modern trucks. My guess is the choke is not working correctly. Get that fixed first before playing with the timing. When these trucks were built they specified anywhere between TDC to 4 degrees BTDC and they worked OK, didn't stall when cold.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
What tdangle said ---- Probably need to adjust the fast idle screw.. This is done while the engine is cold and the choke is still engaged before the engine warms up..
#6 | |
And then the choke doesn’t work like it should because the stove is cold, so we compensate by cranking up the rpm so it slams into gear. So you clean it all out, make it like new or find a way to compensate the running condition. Timing, jetting, heat to the intake all help. |
Thanks for the responses/ideas . I have a new carb on the way and I hope it will be better with the new setup . I think the timing is good (HEI) not sure where it is set . I will play around with it and let you know how it goes .
laying low
![]() Join Date: Mar 2001
A good rule of thumb I've always adhered to is get the timing correct 1st before making carb adjustments.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Who Changed This?
![]() Join Date: Jan 2013
Isn't the saying something like, "95% of carburetor problems are in the ignition"? Not saying it's the case here, it does look like the choke may be out of adjustment, since he says that the truck runs OK once warmed up.
#10 | |
laying low
#11 | |
3 years on mine and been flawless RRM
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
