Old 09-16-2020, 05:39 PM   #1
65chevysub
65chevysub's Avatar
Rear window rubber question
Are there 2 different rear window seals for the 81-87 pickups, for original slider, and solid glass windows? I picked up an original 84 slider for my 84 Sierra, to get rid of the solid glass, and was told the original rubber seal wont work on original sliders. Can someone verify this for me please? I have an original style metal topper with a slider in the front so the window I picked up will be perfect for the truck.
Thanks everyone
65chevysub is offline   Reply With Quote
Old 09-16-2020, 06:20 PM   #2
TKCR
TKCR's Avatar
Re: Rear window rubber question
Thanks everyone
Two different seals. One is bigger than the other, can’t remember which goes with what.
Old 09-16-2020, 06:43 PM   #3
Gerty68
The wider gap seal is for the slider. The thin is for the glass. Good luck!
Gerty68 is offline   Reply With Quote
Old 09-16-2020, 06:57 PM   #4
sweetk30
sweetk30's Avatar
most aftermarket sliders had a lip to let them pop in the solid glass rubber .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-17-2020, 09:12 AM   #5
65chevysub
65chevysub's Avatar
I've done a Google search to no avail, so I'm guessing I'm going to have to find a good used one then.
Thanks everyone
Old 09-17-2020, 10:37 AM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Ive pulled many a solid rear glass and installed an aftermarket slider without any issues
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-17-2020, 12:23 PM   #7
65chevysub
65chevysub's Avatar
Thanks, old rusty. I'll give it a shot. The seal feels pretty soft and pliable so hopefully no issues
Old 09-17-2020, 05:24 PM   #8
Gerty68
I’m sorry if I wasn’t very detailed in my first reply. If you have a OEM aluminum frame slider then you will need a wide gap gasket for it. Anything else (factory tempered back glass and/or most AFTERMARKET sliders are going to be in the thin gap gaskets. Hope it helps.
Old 09-17-2020, 07:10 PM   #9
K25alive
I did some research on this when looking for a seal for my OEM slider in my 1979 K25. The GM part numbers are 363110 or 15593323 for Rear window seal w/rvl. Or 363109 or 15590421 for Rear window seal w/o rvl. I pulled a 363109 and a 15590421 from junkyard trucks, ended up using the 15590421. I think I still have the 363109.
K25alive is offline   Reply With Quote
Old 09-17-2020, 11:02 PM   #10
65chevysub
65chevysub's Avatar
Thanks everyone. I have a line on some squares here in Arizona so may see if they have a gasket
