Old 09-16-2020, 07:46 PM   #1
Phungki
Phungki's Avatar
Does a patch panel exist for here?
I cant seem to find this available so i thought id ask here, ya’ll seem to know your stuff.
Phungki is offline   Reply With Quote
Old 09-16-2020, 07:55 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Does a patch panel exist for here?
Is that the kick panel,.?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-16-2020, 09:24 PM   #3
Phungki
Phungki's Avatar
Yes except that seems to be the mirror image of the passenger side but now that i know it’s correct name i can refine my search
Old 09-16-2020, 11:50 PM   #4
mongocanfly
https://www.classicindustries.com/sh...q=Kick%20panel
The above pic is driverside
Below pic is pass side
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-17-2020, 08:16 AM   #5
Phungki
Phungki's Avatar
Yeah thats it. I was thrown off because the drivers side has a larger vent opening and does not have the square opening above the vent opening.
Thank you!
Old 09-17-2020, 10:06 AM   #6
Rickysnickers
Rickysnickers's Avatar
rotated
Old 09-17-2020, 01:05 PM   #7
mr48chev
mr48chev's Avatar
Left https://www.classicparts.com/1955-59...tinfo/44-115D/
Right https://www.classicparts.com/1955-59...tinfo/44-116D/
I also found the right one on Ebay with measurements https://www.ebay.com/i/391917980606
Same Dynacorn part number for the left one on Speedway https://www.speedwaymotors.com/Dynac...%20(Mar12_2019)
Here is the right one https://www.speedwaymotors.com/Dynac...vy,401342.html
I'm not a big Speedway fan but that is a 100 buck total difference from the truck trinket shop prices. 173.99 ea as apposed to 224.95 From all of the classic truck parts shops who seem to always have the same prices across the board.
My ongoing truck projects:
Old 09-17-2020, 01:46 PM   #8
dsraven
I recommend, before you order anything, to check under the floor where the cab mounts are. if that part is rusted then the under floor parts, which weld to that, are likely gonna need some help too. the step is also connected in the bottom of the hinge pillar as well as the lower fender mount. there are a few other parts you may need. inner cowl needs to come off if doing the whole panel, for one.
here is a link to the assembly manual showing how it all goes together
https://www.trifive.com/d1/55-59Assy.pdf
sheet 6 and on
do some good precise measurements and X brace the crap outta the cab if you plan on replacing that part. pics with measurement locations work well. when assembling tack stuff together then install the door so you know it fits before final welding. actually, make sure the door fits before you start so you have a baseline. sometimes those replacement panels have the wrong threads for the door hinges so check before installing fasteners. like same size but course instaed of fine threads.
Old 09-17-2020, 03:37 PM   #9
mongocanfly
don't expect a aftermarket part to fit right anyway
the most common ones I could find have speakers
https://www.ebay.com/itm/CHEVY-1955-....c100290.m3507
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-17-2020, 05:06 PM   #10
dsraven
here is a pic of one of my hinge pillar repairs, from the inside looking out, pass side, it helps you understand whats inside there hopefully
Old 09-17-2020, 08:09 PM   #11
mr48chev
mr48chev's Avatar
sheet 6 and on
I agree 100% there, you have to start at the bottom and build a solid foundation before anything will be square on top of it.
Old 09-21-2020, 06:50 AM   #12
Phungki
Phungki's Avatar
Thank you all. Lots of helpful advice here. I have it all planned out now. I just couldn’t find that part for the life of me. Helps when you aren’t looking for “inner vent panel” lol. I didn’t know what else to call it.
Thank you very much
Old 09-22-2020, 04:44 PM   #13
_Ogre
_Ogre's Avatar
i'd cut it out and weld in a patch before spending $300 on a patch
easy peasy
shop air compressor timer
Old 09-26-2020, 08:37 AM   #14
Phungki
Phungki's Avatar
easy peasy
I tried to bend up a patch for that. Three attempts and i threw in the towel lol. The panel wasnt that expensive tho thankfully
Old 09-26-2020, 10:13 AM   #15
dsraven
You can always trim offwhat part of the patch panel you dont need and weld that in.
