Old 09-16-2020, 10:12 PM   #1
CJ2A
CJ2A's Avatar
Blinker switch GMC-vs-Chevy
I decided to to install a new blinker switch in the steering column of my daughters 1963 GMC 1500 PU
I am on my third switch from the same vendor and I was told today, it is a Chevy blinker switch, not a GMC, the part will never work.
The three new repo switches all had different malfunctions.
What I have found all the 1963 Chevy & 1963 GMC pickup have the same wiring (wiring colors and wiring responsibilities). The repo switch plugs directly into the existing wiring System.
Anyone ever experience this with the blinker switch ? I feel like I paid good money for this switch and I should not have to take the switch apart and tweak the wire contacts.
Has anyone tweeked the inter wire contacts of the repo switches to make these repos work ?
48 CJ2A
63 1500 GMC (LS1 w/ Muncie 4spd)
68 RS Camaro
71 K20 BBC & granny 4 speed
95 2500 4x4
17 HD2500 4x4
Want => 67 C10 short bed w/ Manual Tranny
CJ2A is offline   Reply With Quote
Old 09-18-2020, 08:38 AM   #2
Pinchecharlie
Re: Blinker switch GMC-vs-Chevy
Mine is new and wont work right either so Iam following to see if theres one that works better or what guys do to fix them. Thanks
Pinchecharlie is offline   Reply With Quote
Old 09-18-2020, 09:37 AM   #3
jbgroby
jbgroby's Avatar
For me its because I have the Hydramatic Column, NO ONE make a factory or after market replacement, the best you can do is go after market column mounted set up - I did not do that because I don't like the look. YOu can upgrade the column - $$$
jbgroby is offline   Reply With Quote
Old 09-19-2020, 10:12 AM   #4
60-66
60-66's Avatar
1963 GMC Part number 2440829 is a one year only and GMC only part . Super rare. My only suggestion is replace it with a Chevy NOS 1963 switch GM part number 898197. Or buy your switch from American Autowire. They make the best switch. I was able to do that swap in my 63 GMC but used an NOS GM switch. The aftermarket switches fail and remember , its a 1963 ONLY switch.
https://www.ebay.com/itm/NOS-1963-64...p2047675.l2557
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
