Blank METAL instrument bezel??
Does anyone make a blank METAL reproduction of the factory instrument bezel? I've found them in fiberglass, but cant find a metal version.
Thanks!
1972 C20 Suburban 1964 Corvette Coupe 1997 Lexus LX450 |
![]() Join Date: Mar 2012
Re: Blank METAL instrument bezel??
I would say no, I thought about this years ago when trying to decide on a custom gage board.
I would recommend you take the plastic one to Chesapeake Bay Rubber and Gasket in Norfolk off of Princess Anne and see if they can cut one on the Flowjet machine as per your sample. They cut all kinds of patterns in sheet metal, acrylic sheets and plexiglass etc.. https://www.cbrg.net/
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
interesting...ill look into it, thanks!!
Old member
Why not use a old glove box door?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
What I did was take piece of 22 gauge sheet metal, cut it to fit inside the flat part of the gauge panel. I drilled holes for the gauges with hole saws. I painted it with under coat in a spray can so it has a bit of textured look. Then I epoxied it to the the gauge panel. The 22 gauge is thin enough you can't tell do to the raised edge of the gauge panel. I painted the raised edge of the panel semi-gloss silver. I maybe spent about 10 bucks on materials.
I had thought about that...the two issues that came to mind were my inability to weld, thus close up the pushbutton hole on the glove box, and drilling out mounting holes that mirror the factory bezel holes.
Anyone have pics from adapting the glove box door?
#7 | |
If you are interested in a challenge... you can make a hammerform out of plywood and then literally mallet a piece of steel around the form for the shape you want. It's actually fairly easy as long as the parts shape is not overly complicated. It might require some welding around the steering column.
Correct I used the sheet metal to locate the gauge holes in the bezel. Scribed the holes and then used a die grinder to make the gauge hole. I used 5" Auto Meter tach and speedo. Oil, volt, gas and temp are 2 1/6" gauges. In the middle between the speedo and tach I used a 2 1/6" gauge I gutted for the high beam and left and right turn signal. Lots of time in MN winters to do this stuff.
I like it! Planning on doing the same with a set of old school Stewart Warner gauges.
Fine looking cluster there Sir.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
I don't know anything about these parts, but summit carries one that fits in the original bezel. I think Classic Parts carries something similar, but neither offer much of a description of what they are trying to sell..
https://www.summitracing.com/parts/d...QaAp5EEALw_wcB https://www.classicparts.com/1969-72...MaAgdtEALw_wcB
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#13 |
Thanks for the kind words. It was a good project. If you go this route make sure you really clamp down the 22 gauge to a piece of wood on a good drill press. The 5" hole saw wants to walk a bit. Cut the holes first before you finish the outline of the 22 gauge.
#14 |
On more thing I did was fill the screw holes the hold the bezel to the dash.
I drilled the bezel screws out for a 10-24 socket heads. Then I epoxied them in. After that I used body filler made for plastic and filled the holes then contoured them to match the raised bezel area. The 10-24 bolts extend far enough thru the dash so I can get a washer and nut on the 10-24. |
#15 |
well done....sharp execution!
#16 | |
BlahBlahBlah
