Old 09-17-2020, 12:47 PM   #1
70StepsideC10
Original or Aftermarket Tach
I am starting to put together a tach cluster for my truck. I have found the tins for a good price, and the guy also has an original tach for sale. I asked if it worked and he said it can be tested when I am there to pick up the tins. He is asking $90 CAD for the OE tach. That might sound like a lot to the Americans on the board, but for comparison an aftermarket tach locally is $180, and if I was to order one from the US it would be around $150-$160 with shipping and exchange rate. Saving money is always good, but I would hate to buy the OE tach and have it fail. So I thought I would ask the guys out there that have tachs, either OE or aftermarket, what they thought. Do tachs go bad often, or are they fairly robust? Or should I spring for the aftermarket one and some piece of mind? Thanks in advance.
70StepsideC10 is offline   Reply With Quote
Old 09-17-2020, 03:38 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Original or Aftermarket Tach
I just had the one in the ramp truck go out and I bought it new back this winter. I'm waiting until I get back home to call about it and see if they will do anything on it.
I posted this back when I bought the tach after finding his site on e bay.a
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-17-2020, 07:31 PM   #3
70StepsideC10
Thanks for sharing that Andy. I didn't know you could get replacement tach circuit boards, that is a great option for failed OE tachs. Good luck with getting a replacement for your failed tach, hopefully they can send you a new one.
Old 09-17-2020, 08:03 PM   #4
custom10nut
custom10nut's Avatar
So Andy. Does this new circuit board work?
I have my old Factory Tach that I’d like to fix for a future project, but if this won’t work then I won’t order one.
custom10nut is offline   Reply With Quote
