09-20-2020, 04:44 PM | #1 |
Suggestions to seal a new thermostat switch in manifold
Guys, with the help from this forum I just installed a new Champion aluminum radiator with dual electric fans. I installed the thermal switch (185/170) that I purchased in a relay kit for the fans. The instructions recommended not to use any thread sealant because it may interfere with making a proper and consistent ground. I also read somewhere on the forum not to crank down too hard. Unfortunately I still get a small amount of coolant leaking around the threads. Anyone have suggestions to stop the leaking?
1970 C-10 CST, LWB, 402/400, A/C |
09-20-2020, 04:47 PM | #2 |
Re: Suggestions to seal a new thermostat switch in manifold
Take a marker, mark where it tops out at the manifold, then use teflon take for 3 threads past that line.
09-20-2020, 04:49 PM | #3 |
ok, will give it a go!
09-20-2020, 06:07 PM | #4 |
I would not use teflon tape for that application, as you need to ensure electrical continuity for the switch to work. I would use a gasket sealer - my preferred sealer is Permatex Aviation Form-A-Gasket.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
09-20-2020, 06:21 PM | #5 |
I had the same problem when I installed the temp sensor in the left cyl. head. I used Permatex thread sealant and no more leak and the gage reads just fine.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
09-20-2020, 08:25 PM | #6 |
About how much sealant should I put on the threads?
09-20-2020, 09:01 PM | #7 |
Just wet the bottom three or four threads. Then you can wipe off any excess on the exposed threads.
09-20-2020, 09:08 PM | #8 |
I use 3 to 4 wraps of teflon tape 30 plus years no leaks no gauge issues
Need to insure both sending unit and npt port are clean and free from corrosion The threads cut through the tape make continuity and the tape seals the gaps between the low points on the threads sealing it in Old broken record wives tail dont seal the threads The only time you dont seal the threads is when there are other mechanical means of sealing example Flared fitting on a brake line Search the board this comes up about every 3 months |
09-21-2020, 09:52 AM | #9 |
Thanks guys, I'll try both methods!
