09-21-2020, 11:43 AM | #1 |
Rear Drum and brakes
Good morning. I did some searching and couldn't find an existing thread that has the information I am looking for. In my introduction thread I mentioned that recently purchased a 1965 c20 that had brake problems. I have rebuilt the brakes and I am about to re-install the drums. Is there anything I should do before hand? Such as with the bearings or anything. Also, are there any torque specs for the lug nuts and axle flange bolts? Thanks and sorry if I missed the thread where this was discussed. I also apologize if I am getting any terminology incorrect.
09-21-2020, 03:15 PM | #2 |
Re: Rear Drum and brakes
The best investment you can make is a copy of the factory repair manual. All the usual vendors sell reproductions in either paper or CD. Most all the info you will ever need.
Good luck with the project
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
09-21-2020, 04:26 PM | #3 |
Do you know where I can find the factory repair manual? Thank you!
09-21-2020, 08:44 PM | #4 | |
Who Changed This?
http://67-72chevytrucks.com/vboard/s...ghlight=hatzie As far as replacing bearings, unless you see gear oil leaking onto the brake drums, don't touch them. Torque specs for every fastener are in the files in the attached link. HTH
09-21-2020, 09:26 PM | #5 | |
03-14-2021, 01:04 AM | #6 | |
I apologize for bring up my old thread. I am getting back to working on the truck after I got roped into home repair. I looked over the manuals and found the following under bearing adjustment following the wheel drum installation guide:
I also found the following video Youtube Video. It shows him using the method above. However, when you view the section of the same video Same Youtube video he easily removes them by hand also. Any guidance on the procedure would be invaluable. Thank you. |
03-14-2021, 04:31 PM | #7 |
I think its that backing off 1/8 turn that does it. I would guess that once that bearing is torqued in and seated, that it doesn't take but that wee bit to make the nut come off easily. I always give my wheel a good shake before I let the jack down too just as a precaution to look for bearing slop.
