Old 09-21-2020, 01:19 PM   #1
fun in dirt
fun in dirt's Avatar
tailgate hinge lengths & size
So are tailgate hinges off later 70s square trucks the same as on '72s?
If have a set already off a '78 or such & it looks to be the same but wasn't for sure if I should use or not for whatever reason.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 09-25-2020, 04:27 PM   #2
fun in dirt
Re: tailgate hinge lengths & size
Nobody???
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 09-25-2020, 04:42 PM   #3
Boog
laying low
Boog's Avatar
I don't know the answer but if you look at LMC catalog for 67-72 and 73-87 trucks and look for tailgate trunions you can find out if they have the same part numbers. And stepside or fleetside tailgates may make a difference.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-25-2020, 06:30 PM   #4
Scurry67
I used one off a squarebody as it allowed a way for me to remove the tailgate without having to remove the trunion bolts. Had to modify the tailgate slightly to make it work.
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 10-30-2020, 09:01 AM   #5
fun in dirt
I like the idea of square body trunions & ability to remove tailgate easier.
But I was actually talking about the length of these...
Square body ones are about an inch shorter & will not let tailgate lay flat when open.
'85 K30 "Big Nassy"
'06 C1500 WT...DD
